80 kz650 exhaust
- kzbobber2
- 1980 kz650
08 Apr 2010 17:42 #359339
by kzbobber2
80 kz650 exhaust was created by kzbobber2
how do you remove the mufflers from the headders are they tacked on or slip off or do i have to cut em
- Bluemeanie
- Thank you received: 14
08 Apr 2010 20:42 - 08 Apr 2010 20:42 #359396
by Bluemeanie
Replied by Bluemeanie on topic 80 kz650 exhaust
Are you talking about a KZ (F1) or an LTD (E1)? On my KZ the inner pipes are permentaly connected to mufflers. Both outer pipes are slip fit with gasket and clamp same as cross over pipe.
Last edit: 08 Apr 2010 20:42 by Bluemeanie.
- kzbobber2
- 1980 kz650
09 Apr 2010 08:11 #359458
by kzbobber2
Replied by kzbobber2 on topic 80 kz650 exhaust
mines a e,and the diagram is it! thx
- kzbobber2
- 1980 kz650
09 Apr 2010 08:13 #359459
by kzbobber2
so how do i get the muffler tips off?
- Mellvis
- Thank you received: 3
09 Apr 2010 13:50 #359531
by Mellvis
Replied by Mellvis on topic 80 kz650 exhaust
If yours is the stock 4 into 2 it should be the same design as the diagram shown, only the head pipes are crossed. The 650D from 78 and 79 has the same pipes as your 650E. I don't remember if the D and E head pipes all four come loose from the mufflers, or just the outer pipes come loose from the mufflers.
- OKC_Kent
- Thank you received: 20
10 Apr 2010 10:31 #359683
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic 80 kz650 exhaust
The exhaust on my 78 B model looks the same as that diagram. The mufflers are welded on. You will have to cut them off, and any replacement muffler will need to be clamped on the pipe or welded. If you need clamps and muffler adapters check JC Whitney.
Oklahoma City, OK
- Thank you received: 2829
10 Apr 2010 10:40 #359685
by 650ed
Replied by 650ed on topic 80 kz650 exhaust
Why would you want to remove the mufflers? Your bike will run like crap without any backpressure. Ed
- Thank you received: 2098
10 Apr 2010 12:05 - 10 Apr 2010 12:06 #359694
by Patton
Replied by Patton on topic 80 kz650 exhaust
If existing stock exhaust system is in decent condition, might sell for enough to purchase an aftermarket system deemed more suitable. Or perhaps a trade might be possible.
Last edit: 10 Apr 2010 12:06 by Patton.
- kzbobber2
- 1980 kz650
11 Apr 2010 07:44 #359915
by kzbobber2
it would run fine even without the mufflers,ive seen it done,with a rejet. motors a motor right,just got headers on my race car
- kzbobber2
- 1980 kz650
11 Apr 2010 07:45 #359916
by kzbobber2
thanks
- kzbobber2
- 1980 kz650
11 Apr 2010 07:48 #359918
by kzbobber2
dare to dream everyone
- polkat
11 Apr 2010 18:42 #360000
by polkat
Replied by polkat on topic 80 kz650 exhaust
My '82 KZ750-4 is the same setup. I think all the Kawa 4's were that way in that era. Solid to the two inside pipes and removable outer pipes. But why? Did it make it easier to R&R the system?
