- Thank you received: 391
major problems
- Motor Head
04 Apr 2010 09:17 #358357
by Motor Head
Replied by Motor Head on topic major problems
If you have a old spray bottle you can put some soapy water in it, then spray around the head gasket area, especially the area in question, then crank the starter and look for bubbles. Or put the air to it like I said.
- rob220
04 Apr 2010 09:21 #358359
by rob220
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
Replied by rob220 on topic major problems
this was a new gasket set and I have not taken apart yet.I'm gonna get in the garage in a little and see what I can find out first.
1075kit
suzuki tl1000 rim
- bountyhunter
- Thank you received: 337
04 Apr 2010 12:12 #358381
by bountyhunter
Replied by bountyhunter on topic major problems
Have the head and cylinder mating surfaces been checked to be flat and true?
- rob220
05 Apr 2010 06:08 #358506
by rob220
1075kit
suzuki tl1000 rim
ok guys thanks for all the input. I don't know what was wrong but I put oil in the spark plug holes and in the head around the cams and she started. two whole years and I finally heard her run again. sounds strong as ever.
1075kit
suzuki tl1000 rim
