Where to find M17x1.25 bolt?
- thompsonmx100
Re: Where to find M17x1.25 bolt?
31 Mar 2010 21:21 - 31 Mar 2010 21:27
Those pics you showed were of the oil pan the bolts i'm thinking of are the ones under the alt and points cover. So it is 18 then. I would just use those its under pressure. never mind I just reread the post so one has to go to the oil pan. How about this I have an 82 oil pan and oil cooler I'm looking to get rid of. Pm me if you are interested.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
Last edit: 31 Mar 2010 21:27 by thompsonmx100.
- guitargeek
31 Mar 2010 21:52
MFolks wrote:
Nope.
Nope.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- thompsonmx100
31 Mar 2010 21:56
Do you already have an oil cooler? Like said I have one with oil pan. It might come out cheaper for you in the long run.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- guitargeek
31 Mar 2010 22:14 - 31 Mar 2010 23:09
I have an oil cooler from a ZX6R, just no way to hook it up and a ZX6R oil pan obviously won't fit my KZ750.
I might eventually just get the pan, cooler and lines from a GPz750, ZR7 or Zephyr.
I was mostly just curious as to where this mythical M17x1.25 bolt might be found...
Last edit: 31 Mar 2010 23:09 by guitargeek.
- Tyler
01 Apr 2010 12:58 - 01 Apr 2010 13:02
I had the same probelm, I could not for the life of me find that bolt anywhere. I work as a mechanical design engineer and I called places that supply fasteners to the auto industry, and heavy equipment manufacturers. Best I can tell that is a kawasaki purpose built bolt any only they used it. You can find one from another oil pan, or make one on a lathe. Thats about it. BTW Kawasaki dosen't even list that part in thier diagrams either. But it does exist.
I choose to part the barbed end of an oil cooler fitting off, drill and tap it, then install an 1/8 inch pipe fitting. I can post a pic if you would like.
"74 Yamaha DT 400 Enduro
Last edit: 01 Apr 2010 13:02 by Tyler.
- guitargeek
01 Apr 2010 13:31
Tyler wrote:
Yeah, let's see what you came up with...I choose to part the barbed end of an oil cooler fitting off, drill and tap it, then install an 1/8 inch pipe fitting. I can post a pic if you would like.
