Oil on the outside of the engine?
25 Feb 2010 10:15 #350086 by staniel
Oil on the outside of the engine? was created by staniel
Let me start with an apology. I searched the forum, but I found nothing, probably mostly due to lack of vocabulary. If this is covered in another thread, please forgive me and send me the link :)
Yesterday I was riding my 1983 KZ750 L3 and I started hearing a chirping noise. I don't know if this is related, but the noise is new, so I'm mentioning it.
I arrived at home and found oil on the left side of the engine. It's on the ribs that looks like heat sinks a couple inches down from the spark plug. I looked in there and saw something that looks like a seal between the top and bottom of that part of the engine (I believe where the piston travels), so my guess is that seal has seen its last days.
Is this my head gasket? Am I doomed?
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
25 Feb 2010 10:25 - 25 Feb 2010 10:27 #350088 by keith1
Replied by keith1 on topic Oil on the outside of the engine?
probably head gasket...i have not experienced the noise ,but i read posts here before describing a chirping noise associated with leaky head gasket....maybe you can try checking the torque and get lucky....maybe not...good luck
Last edit: 25 Feb 2010 10:27 by keith1.
25 Feb 2010 11:29 #350097 by BSKZ650
Replied by BSKZ650 on topic Oil on the outside of the engine?
if you can post a pic it would help a lot, could be as simple as the half moon seals on the ends or even the tach seal in the center of the head.
may even be as simple as the valve cover bolts are loose.
77 ltd1000, current rider
76 kz900, just waiting
  • Skyman
25 Feb 2010 11:51 #350103 by Skyman
Replied by Skyman on topic Oil on the outside of the engine?
I'll second Keith's head gasket theory. Based on your description, that sounds like where the leak is.
Re-torquing your head nuts may solve the problem. If not, you'll need to pull the head and replace the gasket.
Do you have a factory service manual for your bike? Do you have a torque wrench? That's what you'll need for this project.
West Linn, OR
  • Skyman
25 Feb 2010 11:53 #350104 by Skyman
staniel wrote:
Am I doomed?
Certainly! But not because of this. :P :laugh:
West Linn, OR
  • 9am53
  • homebrew, and some bbq
25 Feb 2010 12:06 #350107 by 9am53
Replied by 9am53 on topic Oil on the outside of the engine?
Based on the wording of your original post you sound like you are new to motorcycle mechanics, am I right? As has been mentioned you are not doomed due to leaky head gasket. A leaky or "blown" head gasket seems to sound aweful because in a car it can be expensive to repair, but in our bikes it's not that big a deal at all. The side of the engine that looks like a heat sink IS a heat sink, we don't have a radiator like in a car, so our motors cool by wind blowing on them. post a pic to show exactly where the oil is leaking from, and as has been mentioned tightening some nuts or bolts may cure the issue. If it takes more work than that it still is not a big deal. I have never done any motorcycle fixing before and did a top end rebuild over this winter, so don't stress
  • Skyman
25 Feb 2010 16:57 #350158 by Skyman
Yep, that's what I love about these old bikes. Just about anyone who can turn a wrench, read a manual, and invest some time and patience can work on them. I too started from ground zero, and have rebuilt the top ends on three bikes now.
As 9am53 wrote, replacing a head gasket is not a big deal. But beware of "mission creep". It WILL happen. Once you get the head off, you'll start thinkin'..."Hmmm. While I'm in here I might as well do a valve job. And if I do that, I might as well also replace the cam chain & rollers. And since I've gone that far, I might as well bore the cylinders out and put in a new piston kit. And since I'm doing that, I might as well..." And it just keeps snowballing. There is a very contagious virus that gets released when you remove the head from a kawi engine. Once you've caught the bug...THEN you are doomed!
:laugh:
West Linn, OR
The following user(s) said Thank You: ccammo
  • Kawickrice
25 Feb 2010 17:19 #350163 by Kawickrice
Replied by Kawickrice on topic Oil on the outside of the engine?
Skyman wrote:
:laugh:
Aint that the truth
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
25 Feb 2010 18:35 #350172 by staniel
Replied by staniel on topic Oil on the outside of the engine?
This forum is my favorite thing.
I'm grateful for the responses! I wish I could claim as true as all you folks, but I'm gonna be taking the bike into a shop tomorrow for the general once-over it's probably never gotten. They're gonna run a compression test (among other things) to determine if it's worth working on it, then, if it is, they're planning a valve adjustment, detective work on the oil leak, spark plugs replacement if necessary and so on.
I'll do the oil change, though :)
I'd be a little frightened to do all the work myself. If any of you folks live in the Seattle area, though, I'd love to watch someone do work on their machine (that's how I learned everything about bicycles).
Thanks again, y'all!
  • testarossa
25 Feb 2010 19:09 #350178 by testarossa
Replied by testarossa on topic Oil on the outside of the engine?
:laugh:
The disease that leads us all to KZRider. It's called Kawius Disassembleus. My name is Josh and I am a Kawaholic!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Skyman
25 Feb 2010 19:16 #350179 by Skyman
Of course, you can take it to the shop if you'd like. And I understand your trepidation about doing the work yourself. But for what it's worth, I'd encourage you to reconsider that decision.
First of all, I'm a little surprised you found a shop that will even touch the bike. A lot of shops won't work on older bikes at all. Second, for me, a big part of the fun of owning a classic bike comes from learning how to do my own work on it. And really, unless you are a total mechanical klutz, or don't have the interest, time, or patience to learn, it's really not that difficult.
You'll need to get a service manual (if you don't have one, they are usually easy to find on eBay), and some basic tools. And as you are probably already finding out, this forum is a GREAT resource for finding answers to just about any problem or question that comes up. Here, you've got a great group of Kawi enthusiasts who love helping others get their bikes back on the road almost as much as we love working on our own bikes. And many of the guys here really know their stuff, and give great advice. And best of all--it's FREE! :laugh:
It's your call, but if I were you, I'd skip going to the shop and work on the bike myself.
Oh, and I'm not in Seattle, but if you're ever down in Portland, feel welcome to stop by. :)
West Linn, OR
  • 9am53
25 Feb 2010 19:37 - 25 Feb 2010 19:38 #350189 by 9am53
Check out my build thread...it might make you feel a little more comfortable seeing another newbie fumble through it. As Skyman said, I thought I was only curing a leaky head gasket (like you have) but ended up taking the motor apart and cleaning and replacing everything...I couldn't resist, and it happened just like he said, kinda funny.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=325522
Last edit: 25 Feb 2010 19:38 by 9am53.
