- Thank you received: 1
Homemade gaskets?
- polkat
I think it partially involves the original thickness of the gasket and how much the torque will compress it, particularly if a pre-compressed material is used. The head nuts on the 750 are only torqued to 29ftlbs after all, and I've seen water pumps on older cars with bolts torqued to more then that, using simple paper fiber gaskets without problems.
I've been told that the base gasket is originally about .6mm, and if a pre-compressed fiber material is used at about that thickness, I don't see a problem? Arguements?
- bountyhunter
- Thank you received: 337
- bountyhunter
I dimly recall the gaskets in my Athena set were in that ballpark which I measured at around .026". The N8904 stuff was a shade thicker at about .031". I figured the compressed final thickness difference is proabably a few thousadths which is negligible.I've been told that the base gasket is originally about .6mm,
- Jeff.Saunders
If you use a thicker material than stock, you will lose a small amount of compression. For every 5 thou, you lose roughly .1 compression.
www.z1enterprises.com
Z1 Ent on Facebook,
- polkat
I'm also wondering about making a head gasket from copper. Would there be a negative side to that?
- T_Dub
- Thank you received: 25
For the amount of times you change these types of gaskets, why not just buy some? They're not exactly expensive.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- bountyhunter
The reason I made one after the new one I put in during the rebuild failed was because I didn't want to wait two weeks to order another one from kawi. The only other problem with ordering one from kawi is you don't know how old it is. It may be new in the package, but it could have been on a shelf quite a while.... after all, these bikes are 30 years old.:ohmy:I might get yelled at, but I'm going to ask a question.
- polkat
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- bountyhunter
My answer was this: I bought a "new" gasket rebuild kit to do the rebuild and the base gasket failed almost immediately (withing the firrst two hours running time). It hardened, cracked and disintegrated requiring me to tear the whole engine down to the rods again and I was really mad. At that point, I didn't trust "new old stock" gaskets since I could not tell their age or quality by looking. So, I bought new (very strong) gasket material and cut my own for the base gasket. The whole engine top end gets built up on that gasket, and I wasn't going to risk another one failing again.Unless it's an emergency, why bother going to all that trouble when real gaskets are cheap and fit perfectly?
For the record, it was an Athena gasket set that failed and the gasket material looked fine to me (not dried or old) but the base gasket failed instantly. A Kawi gasket might be OK, but how do you know how old it is?
