Shim Under or Shim Over?
- beefsquasher
Is it strictly a lift thing, or does it have more to do with how the cam opens the valve?
I have heard of shims getting spit out even with stock cams, and I have heard that somewhere around .400" is the limit, regardless of the cam profile.
Do heavier springs make a difference?
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- PLUMMEN
- Thank you received: 104
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- beefsquasher
I already took out the cross marks in the valve cover by hand with a die grinder. They cleaned up pretty nice, but this seems a bit crude for grinding on the head itself, especially around the lifter bores.
Milling machine? lathe?
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- otakar
www.flowbenchtech.com/porting/CRH/kz-data.htm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
Under bucket shim configuration/conversions...
How the hell are the shims replaced?
Meaning you have to remove the camshafts (lift up) to change the shims for clearance specs.... :ohmy:
That seems like a total PITA... I can also see where due to constant removals, striping a top idler bolt/thread or cam cap bolt/thread would be come highly possible...
No thanks, .365 cams with over bucket shims is good enough for me.... I have enough issues to deal with... :blush: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- roy-b-boy-b
- Thank you received: 103
I can see see me now adding the figures to get the correct shim,ought+oughtequals? :laugh:
When i replaced my head gasket on the 1075 engine everyone was telling me i coul not run a 418 cam. Had me freaked out so i starting reading.
On the Ape site it said no bigger than 418 so i still run 418.
- PLUMMEN
- otakar
theres a certain year i wanna say 82-83 j-series shim over buckets that do a better job of holding in shims versus older style,ive got some in a box someplace ill have to dig up to see if anybody recognizes them.
When you find them take some comparison pictures. I would like to see the differences. I thought they were all the same. As I mentioned before, I am running .420 on a 84 GPz1100 head mounted on a J motor. The head is very well ported and the engine pulls like a monster. All this with SOT buckets. I even took the time to machine down some Titanium SUB retainers so I could use them with the SOT Buckets. 10K RPM and no problems.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- beefsquasher
<RANT>it seems like every time I ask a question about building up my head, I am told to just have Larry Cavanaugh do it, "I'm going to screw it up", "don't bother, its a PITA", and so on. It's not that I don't have enough money to send my stuff out to get done, but simply that I want to learn and to do it myself. I have already ruined a junk head I got on eBay by experimenting. I'm bidding on another right now. I got some EXCELLENT, and very specific advice from Larry on how to port these things, and it is coming along nicely. I love screwing around with motorcycles - it's about the journey, not the destination. If my bike was perfect and never broke and was as fast as a Hayabusa, then what fun would it be? I wouldn't get to take it apart and put it back together again a million times.
</RANT>
But.. back to our regularly scheduled program:
I can't find any info about how you clearance the head for the cams - on Larry's site or anywhere else. Any ideas?
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- kawsakiman
- Thank you received: 6
you need to clear the lifter bucket area and a little on the sealing edge.
i have a j head i bought off e-bay and someone did it with a die grinder. they did a poor job.
you can port it yourself but there is more to it then just hogging it out.
it's hard to see but enlarge the picture and look at the lifter bores and the outside edges where the cam tip would contact.
