- Thank you received: 1
Plugging air suction system?
- polkat
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Bluemeanie
- Thank you received: 14
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- hugo
- '92 Zephyr 750
- Thank you received: 71
- Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- polkat
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- switch
- 1981 KZ1000m CSR
I plugged the hole in my airbox with a plastic furniture leg plug from the local Ace Hardware. Perfect fit, perfect depth, perfect color! This was a KZ1000, but the hole should be the same size, I believe.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
- Tommotbird
Good tip
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Bluemeanie
Just wondered whether if you do remove the emission system. Should you plug the hole in the airbox where the rubber hose enters?
I had a couple of these plastic plugs laying around when I removed my emmisions. They have a foam insert so they are actually tiny little air filters and with some minor trimming it popped right in and has been there for over 20 years and looks factiory. Sorry I can't help you with where to get them.
- polkat
Thanks!
