1100 gpz in kz frame?
22 Nov 2009 07:16 #335184 by freddie900
1100 gpz in kz frame? was created by freddie900
does any one have pics or sugguestions for gpz 1100 engines in a z1,kz,ltd frames? i'm trying to put a 1983-84 gpz 1100 engine in a old school frame?
22 Nov 2009 08:11 - 22 Nov 2009 08:11 #335190 by otakar
Replied by otakar on topic 1100 gpz in kz frame?
Not exactly sure, but I believe there is a diference in the mounts. I would first try to mount a set of empty cases to see if they fit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 22 Nov 2009 08:11 by otakar.
22 Nov 2009 16:54 #335242 by rstnick
Replied by rstnick on topic 1100 gpz in kz frame?
Here are some big engines in kz650 chasis:
1327 cc kz650:
GPz 1100 kz650:
1000 cc kz650:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
22 Nov 2009 17:02 #335245 by freddie900
Replied by freddie900 on topic 1100 gpz in kz frame?
that's what i'm talking about!!!!!!!!!! any close-up's of engine mounts?
22 Nov 2009 18:50 #335258 by PLUMMEN
Replied by PLUMMEN on topic 1100 gpz in kz frame?
1327 cc kz650:
GPz 1100 kz650:
1000 cc kz650:
that 1327/650 combo is just plain scary! :laugh:
23 Nov 2009 05:27 #335326 by otakar
Out of my curiosity, What is the point of a z1 engine in a 650 frame. The frame is quite a bit weaker not all that much lighter and not that much smaller.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 9am53
  • homebrew, and some bbq
23 Nov 2009 05:49 #335330 by 9am53
Replied by 9am53 on topic 1100 gpz in kz frame?
especially with the kz650 badging that makes for quite a sleeper
23 Nov 2009 05:51 #335332 by will61310
Replied by will61310 on topic 1100 gpz in kz frame?
Why not do it? That 1327 has alot more H.P. than a 650. :woohoo:
...1980 LTD 1000...
23 Nov 2009 05:55 #335335 by will61310
Yes, i have seen it done on a kz1000 frame. Just takes a little fabrication..;)
...1980 LTD 1000...
23 Nov 2009 06:04 #335336 by rstnick
The 650 frame actually got more bracing around the steering area than the 900/1000 frames. Had better handling than the early big KZs as well.
Add some bracing in key spots to the 650 frame and your good to go.
No close ups of the engine mounts, sorry.
There were a few post in the Archives that had step by step instructions of putting larger engines into smaller frames.
Can't remember off hand the posters though.
I will look.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
23 Nov 2009 06:16 - 23 Nov 2009 07:32 #335339 by rstnick
Here's a post on 650info with a 750/1100 hybrid:
forums.kz650.info/index.php?PHPSESSID=f7...63193dd&topic=1994.0
And messenger1's 750/1105 in the Archives.
kzrider.com/archive/viewthread.php?tid=26143#pid249139
and here:
kzrider.com/archive/viewthread.php?tid=14814#pid237521
ZMan is another member who had posts on a swap with some description of mounting mods needed.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 23 Nov 2009 07:32 by rstnick.
23 Nov 2009 09:08 #335363 by no name
Replied by no name on topic 1100 gpz in kz frame?
@ Freddie
the GPZ motor fits perfect,you only have to add a second motor mount in the front.
