Clutch Slipping or worse?
05 Nov 2009 11:52 #331662 by cte10
Clutch Slipping or worse? was created by cte10
Recently I've noticed that in 4th and 5th gear when I hit about 7500 rpm at full throttle the engine will rev almost to redline without any increase in mph, then drop back to 7500 and accelerate. If the clutch was slipping, it would make sense for it to do it in the bottom gears where there is more torque on the clutch, but it has never done that, only in 4th and 5th. What's going on?
81 KZ750 LTD H2 Bone stock except for bars and Kerker 4-1
05 Nov 2009 12:07 #331664 by YUKABODOS
Replied by YUKABODOS on topic Clutch Slipping or worse?
I too am experiencing this pehnomina. What gives?
05 Nov 2009 12:24 - 05 Nov 2009 12:30 #331665 by rosken
Replied by rosken on topic Clutch Slipping or worse?
what oil is in your engine? if it is "car" oil your clutch will slip , you need to use proper motorcycle oil, a car has a dry clutch,your bike has a wet clutch.
Last edit: 05 Nov 2009 12:30 by rosken.
05 Nov 2009 12:42 #331666 by cte10
Replied by cte10 on topic Clutch Slipping or worse?
I use honda motorcycle oil
05 Nov 2009 16:44 #331680 by bountyhunter
Replied by bountyhunter on topic Clutch Slipping or worse?
My 750 has horsepower curves for the engine and HP increases linearly up to the peak just before redline so the slippage you have is occuring where maximum HP is. It could simply be a slipping clutch.
05 Nov 2009 17:20 #331686 by timebomb33
Replied by timebomb33 on topic Clutch Slipping or worse?
how much freeplay do you have at the lever i have never in all my years of running these bikes on the street and at the track ever had major clutch slippage if i was you i would redo my clutch adjustment starting at the main adjuster on the countershaft cover then work my way up to the lever you need at least an 1/8" free play at the lever. the cluches in these bikes are pretty much bulletproof.
I THINK MY POWERBAND BROKE
05 Nov 2009 19:48 - 05 Nov 2009 19:50 #331701 by Patton
Replied by Patton on topic Clutch Slipping or worse?
Clutch pushrod adjustment will likely resolve the issue. This is usually specified as a routine maintenance item.
Would also assure sufficient slack in the cable itself, and that the cable is properly lubed and isn't frayed or sticking.
Good Luck! :)
Last edit: 05 Nov 2009 19:50 by Patton.
06 Nov 2009 04:15 #331717 by Old Man Rock
Replied by Old Man Rock on topic Clutch Slipping or worse?
As mentioned, start with your simple adjustments and take her out on a test ride.... If no longer an issue, good to go... If still an issue then proceed to next....
As in my case, not severe slippage but enough for me to go Hmmm, that's not right.... Out with the tools and caliper for some measurements...
The image is for my KZ900 specifications, yours may be different but it gives you an idea of what to measure in the plate thicknesses and springs, refer to your service manual for tolerances...
After 30 years of riding, yeah they do wear out....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
06 Nov 2009 04:43 #331720 by keith1
Replied by keith1 on topic Clutch Slipping or worse?
lotsa people on here use "car oil"....no problems with slippage.......
06 Nov 2009 05:05 #331721 by otakar
Replied by otakar on topic Clutch Slipping or worse?
I started experiencing the exact same thing once I rebuilt my engine and gained about 50% in HP. My clutch is adjusted EXACTLY to spec. It could be an oil or oil additive problem. Because in recent times oils have changed quite a bit and many of the oil manufacturers have changed their formulas and additives, this is my suspicion. The biggest mistake someone can make is to use ANY oil with Molly, Graphite, or STP/ Motor Honey, type additives. I have been running synthetics for years without any problems. after rebuilding the engine I went to a standard mineral oil and a small amount of STP, for the extra ZDDP in it and I started experiencing this problem, It is now time to change the oil, and I will find out if in fact the STP created this situation. Also the assembly lube used on cam shafts and new bearings has Molly and Lithium, a small amount of these can make a clutch slip. Many modern oils are starting to use in place of ZDDP.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
06 Nov 2009 10:54 - 06 Nov 2009 10:55 #331786 by bountyhunter
It is true most oil makers have mostly eliminated the zinc and added some kind of moly junk to "replace" it. It doesn't do the same thing, and about 99% of the oils out there now are no longer adequate for use in flat tappet engines. That is bad for old engines, but that's the way it is now.
Adding STP will give you enough zinc compounds to restore to adequate levels. Some bike clutches will slip using car oil which is labeled "energy conserving" because of the friction modifiers they put in them.
Last edit: 06 Nov 2009 10:55 by bountyhunter.
06 Nov 2009 12:58 - 06 Nov 2009 13:00 #331798 by otakar
Both "Molly" and STP will definitely make your clutch slip. I went to "Redline" oil additive for the ZDDP. The STP will rinse out with time but the Molly will destroy the clutch plates.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Nov 2009 13:00 by otakar.
