Transmissions...
- OldSchoolHr
- Kawasaki z900a4 1976 Croatia, Europe
- School Teacher
Re: Transmissions...
01 Jan 2010 14:32 - 01 Jan 2010 14:34
thanks! oldschool and everyone!
I notice the gpz1100 had it, is this then stronger? and if you whated a lockup clutch or a slipper would you convert to five?
thanks
thanks
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
Last edit: 01 Jan 2010 14:34 by School Teacher.
- Jeff.Saunders
01 Jan 2010 17:03
RonKZ650 wrote:
Unfortunately you can't go on part numbers. Kawasaki often changed part designs during a production run. This is very visible on Z1's where 100+ parts are different on the early bikes, yet the part numbers are the same. For instance - the rear brake hub went thru 3 variations (without any wear indicator panel, with using a decal, with the lettering cast into the metal), yet they all have the same part number. Replacement tanks for the Z1 had the KZ tank design (with the seam underneath to the outside of the tank), but the original part number. Chain adjusters - some were chromed, some were zinc'd.
Shame on Kawasaki - they should have used the Honda style part numbers where the last three numbers are revision numbers.
I always thought the transmissions were the same too. Look at Kawasaki parts lists and all the gears on the A2 are the exact same part number as the MKII. So I think we have a slight difference of opinion. I looked at 2 sources, the modern CD parts list and also the old microfiche cards from 3/82. All gears have the exact same part number unless I'm losing my mind which is entirely possible.
www.z1enterprises.com
Z1 Ent on Facebook,
- mark1122
- Keep twisting it
02 Jan 2010 11:57 - 02 Jan 2010 12:07
I thought z, kz ,mk11 gears were the same too. just dif shafts.
i got a whole trany from MURDOCH RACING ENTERPRISES, (MRE) and they back cut it for me and recomended, and supplied a billet 2nd gear, for my 1327 motor. he never mentioned a MK11 as an option. he could have supllied a MK11 if it was better, he has many spare parts for all KZ's.
www.murdochracing.com/parts.htm
i had a z1 sline crack at the end where the pin goes.
as for the best trany. That would be the GPZ modified to use in a KZ.
The KZ baskets are better than the GPZ.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 Jan 2010 12:07 by mark1122.
