  • Page:
  • 1
  • 2
Kickstarter doesn't turn the engine. 20 Oct 2009 20:05 #328673
  • Nephlyte
  • Nephlyte's Avatar Topic Author
  • To do what is right is to know what you want.
  • Thank you received: 0
Well. my battery has been dying and today it won't turn the engine fast enough to start the engine anymore.
Luckily we're all blessed with a kickstarter in situations like this. But, for some reason my kickstarter won't engage. It just goes down really easy like and doesn't grab the engine.
Then sometimes i'll put my foot on it and it'll grab for one sec, then let go. It did this all of a sudden. A few weeks ago i've had to use the kickstarter and it worked great.
Do kickstarters just fail like that? Sometimes i can get it to engage if i push the engine in gear a little. It seems like a weird problem.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
Kickstarter doesn't turn the engine. 20 Oct 2009 20:17 #328675
  • timebomb33
  • timebomb33's Avatar
  • Thank you received: 10
sounds like a bad spring in the ratchet mechanism.
I THINK MY POWERBAND BROKE
Kickstarter doesn't turn the engine. 20 Oct 2009 20:24 #328677
  • kawsakiman
  • kawsakiman's Avatar
  • Thank you received: 6
let go of the clutch while kickstarting and make sure you're in neurtal.
Kickstarter doesn't turn the engine. 20 Oct 2009 20:46 #328681
  • Nephlyte
You own the bike for 7 years, take the entire thing apart, and you are still an idiot sometimes.
Now that i'm thinking about it. I was holding the clutch each time it failed. Then it would work for seemingly no reason.
I guess i was just used to holding the clutch in while pushing the start button. I guess the starter has been working too well lately.
Last edit: by Nephlyte.
Kickstarter doesn't turn the engine. 21 Oct 2009 04:10 #328703
  • N0NB
  • N0NB's Avatar
  • Blue handles better
  • Thank you received: 19
Disengaging the clutch was my first thought as well. Mr. Murphy taught me that one early on! :D
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
Kickstarter doesn't turn the engine. 21 Oct 2009 06:38 #328723
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
  • Thank you received: 11
HAHA....done that more than once myself.
Build Thread
Kickstarter doesn't turn the engine. 21 Oct 2009 11:29 #328755
  • timebomb33
easy fix,well that was another job well done here on kzr
Kickstarter doesn't turn the engine. 24 Oct 2009 13:40 #329366
  • Nephlyte
Always a job well done. Half the Kz's in this country wouldn't be on the road if not for this site.
Kickstarter doesn't turn the engine. 24 Oct 2009 14:54 #329370
  • timebomb33
yes that is probably true but at least i'm secure in the knowledge some of my 11 bikes will run again someday i hope god willing and if i can ever get enough time.
Kickstarter doesn't turn the engine. 24 Oct 2009 15:07 #329375
  • Locozuna
  • Locozuna's Avatar
Never going to have time if you keep buying 11's to play with! ;)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Kickstarter doesn't turn the engine. 10 Jun 2020 17:00 #827815
  • XtraKrispy
  • XtraKrispy's Avatar
Now what if the clutch was not engaged and it was in neutral?
Kickstarter doesn't turn the engine. 29 Jul 2020 10:53 #831811
  • usa forever
  • usa forever's Avatar
  • Thank you received: 5
Sometimes the clutch cable pops out abduct clutch cover where it goes into the motor and that is in effect pulling in the clutch and taking the pressure off the crank check the cable at the motor,over.
  • Page:
  • 1
  • 2
