Bad news! Right cyl. blows smoke, compression low
- Marcus
24 Sep 2009 07:39 #323640
by Marcus
Bad news! Right cyl. blows smoke, compression low was created by Marcus
Had the KZ400 out for a short ride today. Seemed a little down on power, wasn't idling particularly well. Noticed it blowing a bit of smoke when I brought it back home before I shut it off. Figured I'd pull the plugs and take a look. Right side plug looked a little oily, left side looked dry. I hooked up my compression tester and confirmed my worst fears--60 psi on the right, 142-ish on the left.
Bike has low mileage, it sat for years before I bought it. Had to break the engine loose with WD-40 and patience.
So, I guess my question is, what do I do now? I re-ringed a Dodge Neon 2.0 4-cyl. earlier this year. Is the KZ easier or harder?
Sorry, but I'm a noob when it comes to 2-wheeled vehicles. :blush:
- Johnj
24 Sep 2009 08:13 #323647
by Johnj
Veho vivo - Ago ut veho
Replied by Johnj on topic Bad news! Right cyl. blows smoke, compression low
The KZ will be a lot easier. Half as many parts and they're all smaller too.
- Thank you received: 2098
24 Sep 2009 08:23 #323648
by Patton
Replied by Patton on topic Bad news! Right cyl. blows smoke, compression
Would first assure valve clearances being to specs. Then re-test compression.
Exhaust smoke might possibly be from poor spark quality (related to some ignition issue), or from carb issue such as too high floatbowl fuel level, leaking float valve, sticking or leaking float.
Black smoke is typically from unburned fuel mix.
Blue smoke is typically from worn oil ring and cylinder.
A leakdown test could indicate whether there's blowby past the compression rings into the crankcase, or through a leaking valve seat, or blown head gasket.
Good Luck!
Good Luck!
- timebomb33
- Thank you received: 10
24 Sep 2009 08:26 #323650
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Bad news! Right cyl. blows smoke, compression
if you had to break it loose with wd-40 i'd say it's a good bet that there is rust grooves cut in to the cylinder from where the rings sat in the cylinder in one spot and rusted in place ,it will most likely require an overbore.
- Marcus
24 Sep 2009 08:35 #323651
by Marcus
Replied by Marcus on topic Bad news! Right cyl. blows smoke, compression low
What manual is best for the KZ400? Looking on Amazon, I'm leaning toward the Haynes since it seems to cover a narrower range of years and models. Clymer seems to try to cover more. Anybody have a favorite?
24 Sep 2009 08:38 #323652
by Patton
Would hold out for the official Kawasaki Motorcycle Service Manual covering the specific model, which is imo far superior to any of the aftermarket shop manuals.
Could check ebay.
Good Luck!
Could check ebay.
Good Luck!
24 Sep 2009 08:41 - 24 Sep 2009 08:50 #323653
by Patton
Wonder why the ebay tags aren't working on Firefox?
Last edit: 24 Sep 2009 08:50 by Patton.
24 Sep 2009 08:44 - 24 Sep 2009 08:46 #323655
by Patton
No eBay APP ID and/or Cert ID defined in Kunena configurationebay item number 320425521782
Last edit: 24 Sep 2009 08:46 by Patton.
- harm
- Tom
- Thank you received: 13
24 Sep 2009 09:24 #323661
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic Bad news! Right cyl. blows smoke, compression
I would definately go for the Kaw manual over the Haynes or Clymer.
Keep us posted on the engine work and take pics for us!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- bountyhunter
- Thank you received: 337
24 Sep 2009 13:50 - 24 Sep 2009 13:52 #323689
by bountyhunter
Replied by bountyhunter on topic Bad news! Right cyl. blows smoke, compression low
At 60 psi, that cylinder is not burning the fuel so it might look black out the pipe. Check valve clearance. If it's OK, you have to pull the head.
A kawi manual is a MUST HAVE before you try to rebuild it.
Last edit: 24 Sep 2009 13:52 by bountyhunter.
- Marcus
07 Oct 2009 14:36 - 07 Oct 2009 14:38 #326047
by Marcus
Well, I've recently gotten compression readings up to 80 psi. Adding oil via the spark plug hole does not seem to have any significant effect on the readings, so I'm leaning toward valve seating as opposed to rings. I know the carb on that cylinder isn't right, and the plug is kinda dry black looking.
I adjusted the valve clearance. It was a little tight, but just a little. Set within specs now.
By shining a flashlight in the spark plug hole and pulling the exhaust and looking in there, I find a lot of black carbon.
Smoke is more black/grey than blue.
Got the manual via kz400.com. Nice site.
Last edit: 07 Oct 2009 14:38 by Marcus.
- Marcus
08 Oct 2009 07:32 #326145
by Marcus
Well, by now I assume you all think I'm a moron and gave up on me. If not, here's proof! :laugh:
I rode her again this morning. Seemed a little better at times, but tends to surge at cruise. Noticed that the idle seemed more consistent. Decided to check the compression yet again, with the engine hot, and after reading through the manual, remembering to crank the throttle wide open--which is something I had not been doing previously. Doh!
What do you suppose I got for a reading? The notorious right cylinder checked in with a 170 psi reading. Slightly amazed, I re-checked with the throttle closed--80 psi. Doing the same thing on the left side, I got 180 wide open and like 170 closed.
So this of course brings me back to the carbs, which I knew all along needed help. Apparently, the left cylinder is sucking enough air through the carb to get normal compression readings with the throttle closed, while the same passage(s) in the right carb are totally clogged up.
So... looking for yet another set of antique Keihin carbs.
