Some 903cc questions
  • hardr0ck68
  • Topic Author
  • Who put the what in the where?
23 Sep 2009 19:58 #323587 by hardr0ck68
Some 903cc questions was created by hardr0ck68
Hey all, just looking for some info.
Does anyone know the Outside and Inside diameter of z1 (903cc i believe) cylinder sleeves?
What is the largest popular bore that folks use on those sleeves.
What I am thinking here is how thin can the sleeves get and still be streetable with a good service life.
Thanks! Any information is appreciated!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
24 Sep 2009 00:01 #323600 by APE Jay
Replied by APE Jay on topic Some 903cc questions
I don't like under 2 mm wall.
24 Sep 2009 09:31 #323662 by timebomb33
Replied by timebomb33 on topic Some 903cc questions
with stock 903 sleeves about the biggest you can go is 1015 but if you want to go bigger you can keep the block and bore it for bigger sleeves that you go out to 1197 with and still keep a stock appearing engine.
I THINK MY POWERBAND BROKE
  • hardr0ck68
  • Topic Author
24 Sep 2009 20:27 #323768 by hardr0ck68
Replied by hardr0ck68 on topic Some 903cc questions
Well what I am wondering is what, if any use the 903cc and other liter bike parts could have in a kz650/750 platform.
I noticed the wiseco 810 kit is a bore of 69mm and the 1015 kit (which would put a kz650 up to 857cc) is only 2mm larger.
That got me thinking about how much room there is on a set of 650/750 jugs and if larger sleeves could be fitted relativity cheaply (903 sleeves for example).
I guess the next question is how similar are the dimensions of the pistons 810 vs 1015?
Also how thin is too thin when dealing with the block? Is there any rule of thumb for how much meat you need to leave in the block itself to keep the liners in place?
1977 kz650 c1
25 Sep 2009 17:27 #323920 by MadMac74
Replied by MadMac74 on topic Some 903cc questions
Interesting, I am doing the 810 conversion shortly, and I didn't think of THAT ONE !!:) Press 903 sleeves into a 750 block , yeah, Thad be one killer smallblock. Wonder if the rest of the engine could take it?? sounds cool though!!B)
MAC:laugh:
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
  • ArthurGoVroom
  • I'd rather ride it than shine it
25 Sep 2009 20:15 #323956 by ArthurGoVroom
Replied by ArthurGoVroom on topic Some 903cc questions
I would think the thickness limitation would be not breaking or splitting the jug when pressing the sleeves in. Since the head studs go all the way into the crankcase it's not going to blow the cylinder apart vertically.
Also the distance between the centerline of each cylinder bore and the edge of the stud hole is going to be a limit.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
  • hardr0ck68
  • Topic Author
25 Sep 2009 20:52 #323981 by hardr0ck68
well whatever the limits of the cylinders, I now know my rods will handle it.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...em&item=220483161175
Just picked those up, now back to the question at hand.
Does anyone have a 1015 kit that is not in a motor? I can send you a stock 650 piston and you can take some measurements for the forum.... let us know what it would need in the way of wrist pin, and how it compared in height from pin to dome. I think those are the only measurements that matter other than wall thickness on a 750 block.
If 750 sleeves can go +5mm (to take a 1015 kit) or if 903 sleeves can be convinced to fit, I would love to make a 860cc kz650.
1977 kz650 c1
25 Sep 2009 21:27 #323992 by kawsakiman
Replied by kawsakiman on topic Some 903cc questions
hey rocco,
i do have a 1015 kit with sleeves in a 900 block.
you know the number and what i want.
but for christ's sake, just buy a liter bike all ready would you?
you know the local connections that would make it scream and performance parts for a 900-1000 are easier to get then for a middle weight.
if your a good boy, maybe i will show you "the vault" :woohoo:
  • hardr0ck68
  • Topic Author
26 Sep 2009 06:42 #324023 by hardr0ck68
Steve, I hate when people tell me to buy a new bike. I get it from my friends all the time.
Why hot rod a kz650? Cause I want to... If I was just looking for power I would go out and buy a zx14 and be the fastest thing on the road. Honestly there is no reason to start with ANY 30 year old machine when you want to build a performance machine. Unless that is the machine YOU want to build.
Now Steve could you measure up the parts and let me know what it would take to run the 1015 pistons in a 750?
I think all that i need to know is...
Outside diameter of the 900 sleeves
wrist pin size
distance from wrist pin to piston dome
and casting thickness on the 750 block
The whole idea comes from an article I read about kz650's built to race in the 1970's and apparently the first guys looking for the most powers used z1 900 pistons to get more displacement.
I believe the stock 900 pistons (66mm I think) would only give you 730cc's or somewhere in that neck of the woods.
1977 kz650 c1
26 Sep 2009 08:30 #324047 by timebomb33
i don't have any pistons in front of me right now but the wrist pin size is 17 mm for the 73 to 82 900 and 1000's also the early gpz 1100 the 83-84 gpz 1100's are 18mm.
26 Sep 2009 09:06 #324062 by PLUMMEN
Replied by PLUMMEN on topic Some 903cc questions
that big bore with the short stroke and a good head would be insane if you could make it work! B) but would it work though? B)
26 Sep 2009 14:57 #324100 by kawsakiman
i was not trying to insult you or your bike at all.
all i was saying was the bigger bikes have more readily available parts and the motors are easier to make power out of. your kind of limited for real good performance parts. lucky for us a.p.e started a service for our cams again.
i still have the 784 kit, andrews cams, ported head and smoothbores for my 650.
i spent more on those parts then the 1260 motor.
both are 32 year old bikes and i would not trade either for a new zx-14............
