- Thank you received: 2829
Starting / warming up engine trouble-help!
30 Aug 2009 05:18 #317518
by 650ed
Replied by 650ed on topic Starting / warming up engine trouble-help!
One last thought... You should be running ND W22ES-U (my preference) or NGK B7ES spark plugs. If you're not, get a set, set the gap to .7 - .8mm, and use a torque wrench set at 18.5 - 20 ft lbs. to install (you really don't want to strip the spark plug hole threads). These plugs are the correct heat range for your '78 KZ650. Ed
- Kawastep
30 Aug 2009 05:55 #317526
by Kawastep
Replied by Kawastep on topic Starting / warming up engine trouble-help!
Wow, that is alot of good advice . Thanx again and I will keep you updated.
