- Thank you received: 2098
Another baffle question
- roy-b-boy-b
- Thank you received: 103
- saxjonz
- KawboyZ
- Thank you received: 76
By the way my comp baffle is not a vance and hines baffle and the hole is bigger. When I run it at WOT it certainly sounds like an open baffle but when I run normal it sounds mean but on the quiet side of mean like legal mean. It's still way louder than the stock baffle. Just the ticket to avoid the fuzz. I will post a picture of it if you like.
roy-b-boy-b wrote:
I would politely like to disagree. I have been gassing these bikes ever since i started riding to get them to run better than stock.
The first thing i do is remove the restricted mufflers and install headers.
The next step would be to jet it up to match those headers with the packing removed.
And when we use to do a lot of street racing jet it up some more so you could run open headers.
I agree normal street riding would benefit from some restriction but the way i use to ride would not be considered normal.:woohoo:
I really have calmed down in the last year. No one around here rides kz's and i don't have to one up my old friends that would try and wring everything out of these bikes. Roy
79 LTD B3
- roy-b-boy-b
I then found another old kerker baffle.The one that looks like a aluminum cone. I cut it down so it would fit About three inches into the tip. I also cut "v" shaped notches on both ends so it would flow better.
I drilled a lot of holes in it and the sound is not as loud as the wire mesh type with the packing removed. Roy
- roy-b-boy-b
- saxjonz
- KawboyZ
Here it is.
kzrider.com/index.php?option=com_joomgal...l&id=4222&Itemid=117
79 LTD B3
