- Thank you received: 12
"POP" goes the spark plug
- oldkaws4ever
- Have no regrets...... You only live once.
19 Aug 2009 02:00 #314977
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
"POP" goes the spark plug was created by oldkaws4ever
Well i got myself motivated enough to get my 77 kz 650 b1 back on the road, i put in 4 new spark plug's and i made sure they were tightened down enough. Road it around for a bit and all was well. So i decided to take it to work, it ran like a raped ape on the way there with no problems at all. When i was on my way home i was cruising along and decided to lay into it a bit. Then i heard a loud "POP", so i hit the kill switch and pulled over only to find my spark plug in my #3 cylinder completley blew out. I looked on the plug hole and it was completley smooth, with no threads left.................crap. So i limped it home with the #3 plug out. Im guessing i need to do a thread insert, any ideas on what size i need? Any recomendations on how to do it? Im bummed i just got it running really heathy. Here is a list of the mods on the bike, a 710cc kit, 26mm mikuni's off of a kz 1000, pod air filter's, and a 4 into 1 vance and hine's pipe, with the regular baffle fitted with the fiberglass removed, it has dyna 3ohm coils, and dyna copper core wires, im still running point's but they are brand new.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Samwell
19 Aug 2009 02:31 #314979
by Samwell
Replied by Samwell on topic "POP" goes the spark plug
Timesert makes a product just for this. I've just their stuff to repair ruined threads in the block of my kz1000. It's quality stuff. I've purchased some kits from an Ebay store "toolsqwik" He carries a decent inventory and ships quickly.
Check out their website: www.timesert.com/html/sparkplug.html
hops this helps...
hops this helps...
- boots
19 Aug 2009 08:36 #315023
by boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
Replied by boots on topic insert
I got mine at Napa. Happened to my #3 plug also! Something with that 3rd cyl.??The kit comes with a tap & 3 inserts makesure ya use the right one. GL
Later, Boots
Later, Boots
81 cb650
- dardoonk
- Enjoy life....... ride alone
19 Aug 2009 20:23 #315182
by dardoonk
My Bikes:
05 Triumph America
77 Suzuki GS750
82 Kawasaki GPz1100 (White Euro clone)
Replied by dardoonk on topic insert
Number 3 cylinder here too........... Timesert fixed it
My Bikes:
05 Triumph America
77 Suzuki GS750
- timebomb33
- Thank you received: 10
19 Aug 2009 21:43 #315196
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic insert
when you get the kit and your going to start doing it put your piston up to tdc on the compression stroke put lots of grease on the cutter and take your time and pull it it out from time to time to clean out the alluminium pieces also get some Q-tips for after you have made your cut and put grease on it and swab it around the top of the piston so you will pick up any cutting's that have fallen in to the cylinder just take your time and it will work out well for i've had to do it my self at the track a few times between rounds and it has always worked out well for me. good-luck it really isn't that bad of a problem.
- oldkaws4ever
20 Aug 2009 00:48 #315208
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic insert
Wow.......thanks for the replies guy's. I will take your advice timebomb,i piced up a timesert today......i already have the kit from when i stripped the plug hole on my z1 a couple years ago. Hopefully if all is well i will be riding it again this weekend............thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
- Thank you received: 225
20 Aug 2009 05:21 #315222
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic "POP" goes the spark plug
Whoa, are you accomplishing this with the head on the engine? :blink: Please say it isn't so....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
20 Aug 2009 05:44 #315225
by timebomb33
Replied by timebomb33 on topic "POP" goes the spark plug
if your carefull it is very do able with the head still on the engine i've had to do it myself a few times
- Old Man Rock
20 Aug 2009 08:49 #315238
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
I realize your experience over mine Tim but that would just make me way too nervous...
With my luck, I'd probably drill a hole right through my piston dome...:blink: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- tw..
20 Aug 2009 09:06 #315240
by tw..
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
Replied by tw.. on topic "POP" goes the spark plug
I did mine with the head on and it was easy. Use lots of grease, clean the cutter and re-apply new grease until you've cut threads all the way through. Just take your time.
2-1976 KZ900 A4
1978 Z1R
- Kawickrice
- Thank you received: 18
20 Aug 2009 12:15 #315269
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic "POP" goes the spark plug
I lost #4 on a 900 one time but the insert was still on the plug. Previous owner must have butched it because I had to buy a new head
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- oldkaws4ever
20 Aug 2009 23:36 #315465
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic "POP" goes the spark plug
I put the timesert in tonight, i did like you said timebomb and it worked perfect, lots of grease on the cutter.....there were no shavings in the motor. Im going to leave it cure over night......hopefully i will fire it over tommorow and all will be well.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
