Kick start question
06 Aug 2009 21:13 #312130 by mzandmz
Kick start question was created by mzandmz
I cant figure out how to kick start my 77 KZ650. It has a cluch lever switch. But you dont want to have the clutch pulled in to start it or it disingages the engine from the kick starter. What gear do you kick it over in and how do you keep the bike from moving forward? I am a real newbee and a little slow.
New to Family, 1979 KZ440 LTD
06 Aug 2009 21:29 #312134 by Sandy
Replied by Sandy on topic Kick start question
Bike has to be in neutral,gas on,choke on,key on...
1977 KZ1000 A-1
06 Aug 2009 21:36 #312137 by MFolks
Replied by MFolks on topic Kick start question
The clutch lever has a safety switch you have to open to be able to use the electric start function.Squeezing the lever will have a spring loaded plunger move out closing the start circuit.
It's a safety device like I said above to prevent cranking the engine in gear.
06 Aug 2009 21:56 #312141 by mzandmz
Replied by mzandmz on topic Kick start question
Doesn't neutral put the transmission from the engine in free motion. Or did I forget to put the gear back on the kick starter shaft.:silly:
07 Aug 2009 08:06 #312193 by TerryK
Replied by TerryK on topic Kick start question
These engines don't have "primary kick start" which means the ability to kick start in gear (like a dirt bike). To use the kicker, make sure the bike is in neutral and kick away.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
07 Aug 2009 10:00 #312212 by mzandmz
Thanks to all your answers. I am now up to date on my stupidity. Thanks again:cheer:
07 Aug 2009 13:20 - 07 Aug 2009 19:09 #312260 by KZ1979LTD
Replied by KZ1979LTD on topic Kick start question
Less than helpful comment deleted.
Get with the program KZ1979LTD!
KZCSI
Moderator
Last edit: 07 Aug 2009 19:09 by KZQ.
  • Royal1MC
  • Is it just me, or is it just great to be on a KZ
07 Aug 2009 13:27 #312261 by Royal1MC
Replied by Royal1MC on topic Kick start question
Please make sure you're on level ground!!!!!!!:S
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
07 Aug 2009 18:39 #312301 by mzandmz
Thanks for calling me stupid. I never had a motorcycle before and never thought about how it worked, So any wise cracks toward me are pointless. Thank you to those that gave me good information. And to the guy that didnt, he can grow up. Give people a break. Were not all at the same level. Thank you
07 Aug 2009 19:07 #312305 by KZ1979LTD
OK I'll try that again, a little nicer this time. Seriously, get an owners manual for your bike and a shop manual and sit down and read both of them thoroughly. If you have no idea how to kick-start your bike how do you plan on getting home if your battery goes dead when you are out cruising. I would also check into taking a motorcycle safety course before you do much street riding. Some insurance companies give you a break on your costs if you take a course too.
07 Aug 2009 20:16 #312322 by mzandmz
Thank you , I have a repair manuel Not a Users Manuel that came with the bike when new that explains how to use everything on the bike.My class starts in 6 weeks for training. So all problems fix. Thank you very much.:woohoo:
08 Aug 2009 08:04 #312369 by FlickeredOne
Replied by FlickeredOne on topic Kick start question
It also helps if you can hold the bike level while kick-starting the bike. This prevents the right two cylinders from starving while loading the left two cylinders. Thus making it easier to start...cold starts can be tricky to begin with until you learn the "sequence" of your own bike. Happy Riding"
'77 KZ 650 B1 / '74 Harley SX 125
