Lets talk about Oil... What are KZ riders using?
  • otakar
  • otakar's Avatar
Re: Lets talk about Oil... What are KZ riders using
08 Aug 2009 18:40
#312502
My 76 900 had about 30K and my 81GPZ had about 22K when I started to use Synthetics. Its not how many miles but how old the motor and seals are. It is never too late. So what if it weeps a little oil. Just wash the bike more often.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • bountyhunter
  • bountyhunter's Avatar
08 Aug 2009 19:42
#312521
toadson wrote:
How many miles did your engine have on it when you switched to synthetic? Mine has 34k now, so I would think it would be a little late to switch without developing some oil leaks.
Urban myth. You can change anytime you want.
  • jswag5
  • jswag5's Avatar
  • whats the big deal about harley, i prefer 4 cyls!!
08 Aug 2009 20:54
#312559
ive been using the Castrol 4t 20w-50 in mine the last 2 oil changes, noticed quieter shifts and less oil seepage as compared to the valvoline mc 20w-50 oil i was using before.
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
  • otakar
  • otakar's Avatar
09 Aug 2009 07:40
#312656
There are quite a few companies that sell "brake-in" oil. "Redline" and "Royal purple being two. Also these companies sell oil which is specifically stated as having ZDDP. I think that any "Mineral" truck oil should be good for this task, and if in doubt, just add a bit of Redline ZDDP additive. This is what I am planing on doing when I put my top end on. I plan on pre-lubricating everything with a blend of STP and Lithium grease, Which is what e we used in the engine rebuild shop I used to work at years ago.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
09 Aug 2009 09:35
#312674
Here is something interesting I found out on the WEB. I think this is a nice bit of info. I also just emailed STP and am curious what info I will get from them tomorrow. Here is the bit from the WEB
Stp In Red & Blue Bottle/zddp Info From Mfg.
Here is the responce i got from STP on the red & blue container oil treatment.
If i read between the lines it looks as though both have enough ZDDP to protect our flat tappet cams,is that the impressioin you guy's get from the responce ?
Scott
Dear Mr. Wheaton,
Thank you for contacting us about STP Oil Treatment - 4-Cylinder. We always appreciate hearing from our consumers.
Unfortunately, the amount of ZDDP in both types of oil treatments is proprietary information. However, I can tell you that the red bottle only contains slightly more than the blue bottle. Both products contain about 4 times the amount of what motor oils once contained. I hope this information helps you.
Again, thank you for contacting us.
Patti Copper
Consumer Response Representative
Consumer Services
__________________
SCOTT
1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S
ORIGINAL #'S MATCH/OWNED SINCE 1978.
1977 KAWASAKI KZ1000 (ORIGINAL OWNER)
1976 KAWASAKI KZ900
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • bountyhunter
Re: Lets talk about Oil... What are KZ riders using?
09 Aug 2009 15:00
#312701
I asked them the same thing and got a similar answer:
Thank you for contacting us about your STP Oil Treatment. We always appreciate hearing from our consumers.
The amount of ZDDP in our product is proprietary. However, I can tell you that when you add one bottle to four to five quarts of oil, you have the same protection the older motor oils provided. Many classic car owners with flat tappet cam motors use our product for this reason. I hope this helps you.
Sincerely,
Patti Copper
Consumer Services
  • bountyhunter
09 Aug 2009 15:05 - 09 Aug 2009 15:06
#312702
Problem is the dilution rate for a four quart crankcase is about 15/128 which is about 12%. So, if the STP concentration is only 4X, you will end up with a ZDDP level of about 48% of nominal..... which is still way better than not having any at all. Looks like two cans of STP would put you up to close to 100%, but would raise the viscosity quite a bit as well.
Last edit: 09 Aug 2009 15:06 by bountyhunter.
  • otakar
  • otakar's Avatar
09 Aug 2009 17:10 - 09 Aug 2009 17:11
#312728
The way I understand it is that those levels are at, when mixed with 4-5 quarts of oil. Besides that I will still be using the Redline additive and the truck oil.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 09 Aug 2009 17:11 by otakar.
  • bountyhunter
09 Aug 2009 17:30 - 09 Aug 2009 17:35
#312734
I looked at their MSDS sheet and it says the "Zinc compounds" are 1% - 3% in the STP, but doesn't specify what the compounds are exactly. Assuming the center which is 2%, that works out to about 20,000 PPM if I did the math right (just for the STP itself). With a 12% dilution rate, that knocks it down to about 2400 PPM diluted into four quarts of oil which is the right ballpark for what oils used to run. So, it looks like STP does give a decent dose of Zinc even diluted out assuming 2% Zinc compounds (which may be on the high side).
Last edit: 09 Aug 2009 17:35 by bountyhunter.
  • otakar
  • otakar's Avatar
09 Aug 2009 17:59
#312778
Those sound like good #s. Now imagin adding that to some Shell Rotella-T and you will be at twice of what the oils used to have. I also understand that the so called "Hi-Millage" oils are hi in ZDDP.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
09 Aug 2009 18:07
#312788
Here is a nice forum with some very good info about Rotella oil.
www.shellusserver.com/ubbthreads/ubbthre...t&Number=3166&page=2
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • MentalMike
  • MentalMike's Avatar
  • God Bless America!
09 Aug 2009 18:16 - 09 Aug 2009 18:18
#312790
Amsoil released a study of motorcycle oils in June. Open the link to view.
www.amsoil.com/lit/G-2156.pdf
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
Last edit: 09 Aug 2009 18:18 by MentalMike.
