- Thank you received: 1
82 kz550 a2 ticking....Help???
- 550A2
- keep the shiny side up
I am not sure what it could be, the carbs are synced and adjusted properly, the valve clearance and ignition timing are to spec as well as the cam timing. The only thing i havent seen on this bike is the oil filter which hasnt been changed since i got the bike 5 months ago, ive changed the oil though.
If it was circulating unfiltered oil could that cause a tick????
Or am i looking at something more serious?
ALSO, my exaust baffle is shot, what options do i have for a tail pipe set up, i have a 4-1 header.
Thanks guys.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- GPz550D1
- Thank you received: 22
Robert
1981 KZ550-D1
- 550A2
- kano
- Not Another Bloody Limey!
several of us guys double
up the copper rings to solve this issue.
- 550A2
Ill try that right now.
Thank ya!
- harm
- Tom
- Thank you received: 13
What kind of oil are you running? What weight? I use Kaw 20/50 with great results.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- 550A2
The last oil change i did was Chevron DELO 15-40. Its summer here so i run a little thicker viscosity.
I ran it sounds like the sound is coming from the clutch case?.......not the cams.
Im stumped.
they dont teach much about motorcycles in auto technolgy!
- kano
don't be scared we are hereto help.
take a pic if you find something interesting
- 550A2
im gonna do an oil change right now and i just got a new filter about 5 minutes ago.
I acutally have all the bottom and top end gaskets for the engine so i might just do that.
If the clutch is going out would it make a noise like that though???
- kano
pull the cover have a look,
if nothing looks odd,
re tighten the spring retainers.
normally a ticking sound is exhaust so this has me baffled lol.
hopefully on of the hard core will chime in.
- bountyhunter
- Thank you received: 337
Yep, Krazy Glue two copper rings together and the problem is solved.definitely a exhaust leak.
- 550A2
I Just dabbed some hi temp sealant an the edge of one copper ring and stuck it to the other, then sinched em down. Havent ran it yet though. I guess ill see on the way to school tomorrow mornin if it made any difference
I appretiate your help, thanks.
Ill keep ya updated.
