need cam timing HELP
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- Old Man Rock
- Thank you received: 225
"my cam sprockets are diff. "...
Assuming you're speaking of the sprockets that attach to the camshafts, if the bolt holes are slotted or you have bolts all the way around the sprocket than these would be adjustable cam sprockets.
If you did not remove the sprockets off the cams than leave them alone unless you plan on CAM degreeing these in...
I wrote a tutorial on the process...
NOTE: Has some humor/language others find offensive... but the information provided is 100% accurate and does provide you everything you'll need in tools and formulations/step by step process to accomplish cam degreeing...
members.cox.net/ruinsofstei/MOTORCYCLE%2...UCKS%201-28-2009.pdf
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Sandy
- Fly High,Tony
- Thank you received: 13
I'm thinking that you might have a modified engine.
Do you have the head off right now? If so,what's the cylinder bore size?
Got pics of those carbs?
Do you see any grinding marks around the shim bucket area?(clearance for bigger cams)
If you do,you probably have performance cams that have been degreed,like OMR mentioned.
More info and pics would really help...
1977 KZ1000 A-1
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- Sandy
- Fly High,Tony
If so,like OMR said...you'll have to get them re-degreed,or go back to a stock sprocket.
But going to the stock sprockets will limit the capability of those cams,if they're performance cams.
How do you know it was a piece of metal that did the damage?
1977 KZ1000 A-1
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- Sandy
- Fly High,Tony
on the cam chain tower there is rubber spacers with steel plates under them. one rubber and one steel plate was missing when i got the bike.
Yup...that would do it. :pinch:
Were the tower bolts(4 of them in total) still there?:huh:
More info needed,on those cams...any markings on them anywhere?
Check them out...check the ends of them for any stamps.
Pics for sure if you can...clear pics...
1977 KZ1000 A-1
- wes_scooter
5 L on left of sprocket, and a R on rt side
on the end of the exhaust cam is 4 lines 2 vertical 2 horizontial. the intake cam has more lines.
yes the tower bolts are there but i think the father in-law might have done that part. dont know though
76' kz900
70' yamaha R5
2006 wr450f
- PLUMMEN
- Thank you received: 104
- Sandy
- Fly High,Tony
i want my mommy.....the bad man touches too hard....
Takes your meds,Plummen!:laugh:
Hmmm,those ends markings...don't sound like stock cams to me.
Post some pics ok
1977 KZ1000 A-1
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
