Backfiring Issues
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Once I installed the vaccume line that bike ran like a million dollars.
Moral of the story, check the little stuff first before tearing the valve cover off. A lot of times it is something simple that you have overlooked.
Did you check to see if the vaccume line has any cracks, tears, or holes.
For $2.00 all of your troubles may go away.
KRB)
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- KZYoungBlood
I had the same problem with backfiring out of the carbs and do you know what the solution was? After 6 freaking months, I found that it was the vaccume line from the petcock had come off the nipple and thus creating the backfire through the carbs.
KRB)
got the new tires on it today. after a months worth of hard labor. i took it for its first ride. pure bliss :woohoo:
uh... yeah... that vacuum line was missing... forgot to put that back on. doh
that fixed most of the issue. it just pops a little bit. i still have to check the timing/carbs/valves.
THANKS FOR ALL THE HELP GUYS
1981 KZ1000-J1
- 1978KZ650SR
- If it's not one thing, it's something else.
Thanks
Andrew
1978 KZ650 SR - Custom paint, Kerker cooler, 4 to 2 exhaust, inverted clubman bars.
- pitblue/kz
- Old Man Rock
- Thank you received: 225
When was the last time this KZ was tuned up....
Plugs, valve clearances, ignition timing, battery charged, carbs synced etc....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- tinlizzie37
- Thank you received: 1
Bob KZ 650 E1, En 450
- pitblue/kz
- racer54
- Thank you received: 114
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
Always been told if it backfires through carbs, ignition is advanced and if backfires out pipe, ignition timing is retarded. Anyone else heard this?
...and if it backfire out both, the owner is retarded.
:silly:
West Linn, OR
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
