'79 KZ650C misses/backfires
- Hayward
- '79 KZ650
19 Jun 2009 15:24 #300689
by Hayward
'79 KZ650C misses/backfires was created by Hayward
I am new to KZ bikes, please understand I have single cylinder mechanical experience and am trying to help my brother with his latest purchase. The bike cranks fine, will not idle well, even after it warms up. During test run, it spuddered like it was running on 2 cyl. and then it opened up to 4 cyl. As I slowed down, then hit the throttle, it started spuddering again and I let off , it backfires through the right tailpipe. I'm here to ask for some clue before going through the manual(Clymer's)and blind testing the fuel, intake, timing, carb. sync.,& etc., I don't mind trial and error,I just want someone with KZ experience to guide me in the right direction. Thanks for any help. Doug Miller, Vernal, MS
- Thank you received: 2829
19 Jun 2009 16:15 #300730
by 650ed
Replied by 650ed on topic '79 KZ650C misses/backfires
Hi, Welcome aboard! How long has it been since the bike was used on a regular basis? I ask be because if it's been much more than 6 months or so there may be gas crud built up in the carbs and the fuel may be "stale." The symptoms you describe could be any of several different things, but crud in the carbs will definitely make it act the way you describe, so if it's been out of service for a long time that's where I would start. Ed
- timebomb33
- Thank you received: 10
19 Jun 2009 17:12 #300744
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic '79 KZ650C misses/backfires
carb's need to be cleaned properly that is my educated guess give that a try and let us know how it goes for you.
- Hayward
- '79 KZ650
19 Jun 2009 17:26 #300750
by Hayward
Replied by Hayward on topic '79 KZ650C misses/backfires
Thanks for the replies ! I suspected several things myself and could see me slinging parts with one hand and the manual in the other. My brother picked up the bike in Wisconsin at a yard sale. I have no idea how long it has been sitting up but he did mention filling it up wth premium gas. No, he didn't drain or clean old fuel out. Both replies indicate dirty carb. Any tricks I need to know before following manual step by step in removal and assembly ? I've no experience with a 4 carb. setup.
19 Jun 2009 17:38 #300756
by 650ed
Once you get things cleaned up be sure to install a quality inline fuel filter, otherwise hidden crud in the tank will quickly corrupt the carbs again. Ed
- Hayward
- '79 KZ650
19 Jun 2009 17:58 #300763
by Hayward
Thanks, 650ed ! It has an inline on it that I'll replace when done. I'll let ya'll know how it turns out.
- timebomb33
19 Jun 2009 18:03 #300764
by timebomb33
just follow the manual for disassembly and when you get to that point start asking questions if we tell you now it would take all the fun out of it.
- Hayward
- '79 KZ650
19 Jun 2009 18:25 #300768
by Hayward
I hear ya, timebomb33. I was just reading up on carb. sync. and I see a large can of worms in my future.
- baldy110
- Thank you received: 512
19 Jun 2009 18:40 #300772
by baldy110
Replied by baldy110 on topic '79 KZ650C misses/backfires
It's probably going to be dirty / gummed up carbs. However the first thing to understand is the definition of "cleaning". Most people when they clean their carbs take them off, pull off the float bowles spray some carb cleaner in and around the float bowl area until it appears clean. They then put it all back together and have the same problem. That does not consistute "cleaning" you must take all the jets out clean them up making sure the small holes are clear then MAKE SURE all the small passage ways are clean in teh carb bodies and you can spray carb cleaner though every passage. Make sure ever lever and slide operates smoothly. Check float level and if needed adjust. Put everything back together and install on bike.
Next make sure the gas in the tank is good or you will just be allowing bad gas to get into the carbs you spent time cleaning. Good luck
- Hayward
- '79 KZ650
19 Jun 2009 20:38 #300802
by Hayward
Thanks, Baldy. I need all the luck. I just finished removing the carbs from the bike. I'm familiar with carb cleaning, just not four at a time. I'll start cleaning tomorrow.
- Hayward
- '79 KZ650
19 Jun 2009 20:54 #300805
by Hayward
BTW, while removing the carbs, I noticed vacuum line to #1 carb was plugged off with a screw, no retainer springs on air box tubes, and no screws in the air box. Do I need to be concerned with any of this ?
- baldy110
20 Jun 2009 13:45 #300927
by baldy110
Is it the vacumn line or the vent. The vent is the larger of the two. If it is the vacumn line, that one goes to the petckock to keep it open while the engine is running. Sometimes people will install a manual petcock valve on the tank if it has one then that line will need to be plugged.
