81"KZ1100 quick H.P.
17 Jun 2009 21:24 #300091 by Tedster
81"KZ1100 quick H.P. was created by Tedster
Hello
i just picked up an 81"KZ1100 i need to get some bugs worked out on it,
what is the easiest way to get a little more power out of the bike cheap.
i was thinking of putting a 4into1 on it would be cool to find a good used one reasonable,i have to rebuild the carbs any way what do ya think a dyno jet kit or what should i do to get a few extra hp. reasonable
17 Jun 2009 21:28 #300093 by jtmcculloch
Replied by jtmcculloch on topic 81
Best bang for the buck - re-gear it
76 KZ1075
93 ZR1100
71 Moto-guzzi 750
2001 ZR-7S
17 Jun 2009 21:34 #300099 by timebomb33
Replied by timebomb33 on topic 81
the dyno jet kit won't really gain you any extra horse's but it will make the carburation a lot more enjoyable and git rid of any glitches you have.
I THINK MY POWERBAND BROKE
17 Jun 2009 21:42 #300106 by Tedster
Replied by Tedster on topic 81
its a shaft drive
ted
17 Jun 2009 21:42 #300107 by MFolks
Replied by MFolks on topic 81
www.gearingcommander.com to help figure ratios.
17 Jun 2009 21:44 #300109 by timebomb33
before plummen gets on here and say's anything, TURBO. nuff said.
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
17 Jun 2009 23:13 #300133 by kzz1p
Replied by kzz1p on topic 81"KZ1100 quick H.P.
You might try tire height or rim size?? An exhaust pipe for sure. Then I would degree the cams. Carb jetting is very important..........Just a couple of suggestions.
18 Jun 2009 15:46 #300374 by kawsakiman
Replied by kawsakiman on topic 81"KZ1100 quick H.P.
it depends on your Definition of cheap.
buy a set of cams and set lash.
a good header as well.
18 Jun 2009 16:19 #300393 by Tedster
Replied by Tedster on topic 81"KZ1100 quick H.P.
i started looking around and there is not really a whole lot of talk on the kz1100, i think it was considered more of a touring bike.
you can't find any listings for headers or anything,
even on the KZ information list on the site the bike is not listed either,there ain't much talk about the bike nowhere
and actually i think its the only KZ there ain't hardly no talk about,must of not of been one of the desirable ones
the header a guy here told to me to try one off his KZ1000
and see how it fits,how much more power would the cams and pipe give it
Ted
18 Jun 2009 16:38 #300396 by otakar
Replied by otakar on topic 81"KZ1100 quick H.P.
The same parts that will fit the KZ900, KZ1000 the GPz1100 will fit the KZ1100 in most part.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
18 Jun 2009 18:06 #300421 by Tedster
that is good to know thanks
Ted
19 Jun 2009 14:11 #300654 by coppertales
Replied by coppertales on topic 81"KZ1100 quick H.P.
There are no cheap used headers in reasonable condition. Unless you are extreamly lucky. Just buy a new one and be done with it. Any KZ1000 header will fit. I have KZ1100s with stock exhaust and headers and I really cannot tell the difference. The header sounds like you are going faster. But then again, I am an old guy and got the go fast out of the system a long time ago......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
