Why are there two kz1000 motors?
- larrycavan
Re: Why are there two kz1000 motors?
16 May 2009 19:11
Jeff.Saunders wrote:
Don't confuse torque with flywheel enertia.
Enertia Definition
1)Physics. The tendency of a body to resist acceleration; the tendency of a body at rest to remain at rest or of a body in straight line motion to stay in motion in a straight line unless acted on by an outside force.
2)Resistance or disinclination to motion, action, or change.
All things given as equal, flow, port size, bore size, carb, cam, gearing, weight of bike, etc.....between two bikes. The motor will produce the same amount of torque. Torque & RPM being the components of HP.
So this isn't really a matter of torque but one of enertia.
A light crank will rev easier than a heavy crank. But, by the same notion, the heavy crank is more resistant to being pulled down in rotational speed when the load is placed on the engine [leaving the line].
That is very different than the torque produced by the design of the engine.
Things that work for you in one respect can work against you in another respect. There are always compromises to be considered.
Larry C
9am53 wrote:Z1 - so the original Z1 had a lighter crank with the lighter flywheels, how would that affect performance compared to the heavier flywheels? I am guessing the heavier ones will carry a broader torque curve whereas the 900 would seem spritelier but youd need to keep the revs up. is that right?
Yes, the Z1 engines rev very quick, but lack the torque of the 1000's. It's not that they are better or worse, each has advantages and disadvantages.
If you are drag racing, there's two distinct camps - those who want torque off the line, and those who want the revs at top-end...
Enertia Definition
Larry C
- larrycavan
16 May 2009 19:19 - 16 May 2009 19:23
I'm thinking TRA primary clutch....Polaris Secondary....4 wheels....oh yea!
I blew up the pics. That looks like an OEM crankcase casting. I sure don't see any welds to indicate home brewed.
Probably just another example of how Kawasaki was ahead of their time with another innovation.
Last edit: 16 May 2009 19:23 by larrycavan.
- 9am53
- homebrew, and some bbq
17 May 2009 16:29
Larrycaven - so the heavier flywheel makes it slower off the line, but likely when I go up a hill the heavier crank will keep my revs from dropping as dramatically right?
I get how the cranks mass could effect regular driveability, but how could a heavier crank be better in a drag race? or does the heavier crank actually add torque like I surmised earlier?
I hope these aren't dumb, I'm just a very interested newb!
Cheers!
Cheers!
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- tjk
17 May 2009 19:07
The heavier crank launches easier, especially with a big dragrace tire, because it keeps the engine from wanting to bog as badly when the clutch engages. The extra weight of the spinning crankshaft helps it keep the rpm up without the need to slip the clutch so much. Once in-motion, though, the lighter rotational mass will accelerate more quickly, due to less weight needing to be accelerated.
FIDO
- 9am53
19 May 2009 04:32
thanks, makes a lot of sense!
'84 GPz900r
'71 CB350
'71 CB350
- Jack
19 May 2009 11:02 - 19 May 2009 11:11
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 19 May 2009 11:11 by Jack.
- Jack
19 May 2009 11:06
RacerZ wrote:
You don't go on to say whether or not it was a MKII Crank like the one pictured, and whether or not you had the Main Bearing Crank Cap supported. Z1 Crank has a 15T Pin, MKII has 16T Pin (Stronger) for those that may not know.[/quote]
Nope, it was definitely a 15 tooth Z1 crank and supported with a main bearing centre plate.Like I said, I was light and the bike was light.Worked good until it broke...
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Jeff.Saunders
19 May 2009 14:45
Hi Jack, that strange 1000 motor was European. The pictures came from a crazy Swede... ...so probably Nordic or German market only.
The MK II valve cover and engine covers date it as 79 or 80 vintage. I do have some additional pictures of the engine, but nothing very interesting (other than confirming the cases have to be OEM).
www.z1enterprises.com
Z1 Ent on Facebook,
- 9am53
16 Jun 2009 10:08
I'm back with an adition to this thread...looking at my manual, the kz1000J bike (not motor) has 102 hp, whereas my LTD has only 92...whats the deal there? the bikes seem to have the same carbs, what gives the J so much more power?
'84 GPz900r
'71 CB350
'71 CB350
- timebomb33
16 Jun 2009 10:18
the camshafts and some internal pieces in the carbs were different
I THINK MY POWERBAND BROKE
- 9am53
16 Jun 2009 10:23
Thanks
'84 GPz900r
'71 CB350
'71 CB350
- brianrae33
16 Jun 2009 21:26
i'm going to have to agree with anything jeff says..been dealing with him for years and he's never steered me wrong..
1982 kz1000ltd
