- Thank you received: 2
810 engine assembly
- pburnhamb
10 May 2009 08:02 #289822
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Replied by pburnhamb on topic 810 engine assembly
is there also 2 dowels that go inbetween the case halves? one in the front and one in the back?
Also i cant find the 2 dowels that go over the cyl studs, so i went online to order them and i cant find them in the schematics either. any idea why this is?
thank you for your help
1976 kz900
1977 xs650
- pburnhamb
22 May 2009 17:31 #293386
by pburnhamb
1976 kz900
1977 xs650
Can someone please tell me if there are only 2 dowels between my case halves (one on left and one on right)/ there appears to be a spot for one in the front and back as well.......
also, there is are 2 o-rings on the top of the top case half around the 2 cyl-studs (the 2 that are in the third spot counting from the right) is there supposed to be dowels as well as the o-rings or just o-rings. (WHY the need for o-rings arouund these 2 studs?)
thank you for the help, im close to being done i think.
1976 kz900
1977 xs650
- Mark Wing
- Thank you received: 22
22 May 2009 18:57 - 22 May 2009 18:59 #293399
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 810 engine assembly
Two dowels on the cases, one on the right and one on the left. No dowels on the front or rear where it looks like one would fit. The O-rings go around the oil restricters [ the little round things with a small hole on the top] on each side of the cases.
Mark
Mark
Yorba Linda Cal.
Last edit: 22 May 2009 18:59 by Mark Wing.
- pburnhamb
22 May 2009 19:39 #293406
by pburnhamb
1976 kz900
1977 xs650
i saw on bikebandits schematics that there are 2 o-rings on the cyl studs on top of the case between the case and the block. I cant for the life of me figure out why they are there of there isnt a dowel as well......they are #4 under the crankcase breather cover diagram
any ideas??
thanks for your other answer
-patrick-
any ideas??
-patrick-
1976 kz900
1977 xs650
