difference between 82 and 85 gpz 750 engines
- mtkawboy
Re: difference between 82 and 85 gpz 750 engines
02 May 2009 19:07
The intake side of my 82 was ported from the factory but not polished. I put the RC 4-1 header on back on 83 so I dont recall what the exhaust ports looked like
- thompsonmx100
23 Oct 2009 17:27
well I started this thread awhile ago and I thought I was good to go just swap motors well guess what guys there are large differences in these two motors. The cases are completely different. the 82 wont fit in the frame. the engine mounts are too wide.
Thats me pissed I have two fing motors I cant fing use. Next question is can I just buy a set of case and put my guts into them or wont the crank work. Please help
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
23 Oct 2009 18:10
bump anyone know if I can just get a set of cases and set my crank in them and be ok
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- hardr0ck68
- Who put the what in the where?
23 Oct 2009 20:09
something must be wrong. All kz650,kz750,and gpz750 4 bangers should swap into any one of those frames.
If you must change an engine sell the ported motor to me!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- thompsonmx100
23 Oct 2009 20:31
it wont fit i'm telling ya, The front mounts are narrower and the same with the lower rear mount. I thought the same thing Hell I have both of them sitting in my garage and I thought they were the same till I tried to put the 82 in my 85 frame. After I cooled off some I took a look at the 82 I can make it fit I will have to cut the lower rear mount of the motor narrower. I will post pics in my 750 cafe build thread. Then the front I can use the 85 left hand rubber mount but use a flat plate for the left mount. like I said i will post pics in my build.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mtkawboy
24 Oct 2009 18:48
I still trying to figure out how someone broke one, Ive beat the snot out of mine for 27 years now.
- stevie g
13 Jan 2016 04:32 - 13 Jan 2016 05:36
The ZR 750 aircooled, ZR7 and the zephyr 750 have all got norrower cases. I know this cos I fitted a gpz 750 81 engine into my zephyr 750 and had to cut the rear mounts off and re-weld them further out, no big deal. Also had to make up different front mounts. norrower at the front and rear (zephyr etc)
stephen g mackay
Last edit: 13 Jan 2016 05:36 by stevie g.
13 Jan 2016 04:44stevie g wrote: The ZR 750 aircooled, ZR7 and the zephyr 750 have all got norrower cases. I know this cos I fitted a gpz 750 81 engine into my zephyr 750 and had to cut the rear mounts off and re-weld them further out, no big deal. Also had to make up different front mounts. norrower at the rear and wider at the front (zephyr etc)
You just replied to a 6 YEAR OLD thread. :silly:
Regarding the cases, Kawasaki evolved from a solid mounted engine scheme to rubber mounting, thus the evolution of the engine cases.
- stevie g
13 Jan 2016 05:39
Doesn't matter how old it is, It's still relevant especially as these bikes are getting older and folk are looking to see what other engines will fit what.
stephen g mackay
- scubaanders
Re: Re:difference between 82 and 85 gpz 750 engines
13 Jan 2016 06:09
Tks for bumping this tread, as me and my buddy yesterday was debating if the engine from my 83 would fit my 82.
Now we have all the answers.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- stevie g
13 Jan 2016 07:07
No probs bud. Here's a rundown of my Zeph 750. Gpz 750 81 engine, Had to cut the front sprocket outer engine cover a little to clear the frame the pickups were a straight swap as were the carbs and boots. I used a ZX9R E1 rear wheel . with a 180 tyre fitted and a 525 chain conversion with a 17 tooth sprocket at the front and a 39 at the rear. fitted a zeph 1100 swinger straight in and 1100 shocks , It's about 1 1/2 longer than the 750.. Didn't have to get offset sprockets either as it all lined up OK. At the front I fitted ZX9R RWU forks/ yokes and a KR1 wheel so I could keep the original speedo mechanical drive. both wheels match, ie 3 spoke mags. I've just bought a ZR7 bottom end as it has the primary chain tensioner unlike all the other 750 -4s. I intend to fit a 750 UT head and cams and take it out to 810 when I can afford it. Might also fit a 6 speed box from any of the 550 4s. and lastly I fitted ZR7 standard headers and made my own silencer from a short piece of stainless steel from ebay which I fitted with an old baffle and welded a bracket on. As far as I could see all engine internals are identical except there is a different end cap/bearing on the shaft that the clutch pushrod goes through, it's blanked off on the Zeph as it's a different setup. Has to be sprayed yet and the tank is wrong in this pic, 550 fitted for now.
stephen g mackay
