Adjusting valves...
- Pro_window78
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- Thank you received: 2098
I believe I need to adjust my valves but I want to check them first. My bike is a 78 kz1000 a2, I am pulling the valvecover anyway to replace the leaky gasket. I have feeler gauges. Where do I measure the clearance and what should it measure? Thanks, Ryan
0.05-0.10mm (.002-.004 inch) clearance between cam and shim (with cam lobe pointing away from shim).
Use 17mm "nut" to rotate crankshaft (not the 13mm bolt head at end of crankshaft). Okay to use kickstarter where so fitted.
Crankshaft rotation is easier with sparkplugs removed to prevent compression.
Good Luck!
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
don are you slagging my favorite tool that motion pro makes the old two piece adjusting tool i really don't know why people don't like that one it will only bark your knuckles the first few times you use then get the routine down . what doesn't kill you can only make you stronger right. :woohoo: :woohoo:
Gettin the routine down includes round-filing the lever piece and using only the batwing.
A little fiddling while holding the batwing in position with the cam lobe holding the bucket down, and carefully rotating the crankshaft (by hand with the 17mm "nut") will permit the batwing to catch the edge of the bucket and hold it down while the cam lobe turns away allowing removal/replacement of the shim.
Be extra careful when rotating the crankshaft to assure the other valve in the same cylinder is NOT opening so as to contact the valve being held down by the batwing. Don't want both valves open at the same time. In other words, assure the batwing isn't holding one valve open while the other cam is opening the other valve. The objective being to prevent bending a valve.
Good Luck!
- timebomb33
awe come on real men can push down that valve spring are saying the your a wuss patton finding the easy way out.
Must be thinking of somebody else! :laugh: :laugh:
- timebomb33
- Pro_window78
- timebomb33
- Old Man Rock
- Thank you received: 225
I purchased and tried using that tool for about 10 minutes... Screw it, through it to the floor and since I already had my dimensions/new shims, loosened the cam caps to install...
Now with some finesse and some minor tweaking of the tool I'm sure it would work but so would my elbows if tweaked..... :huh:
Me personally have not found this tool to be worth a crap as is especially for those of us that went with heavy duty valve springs....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
