cool!!! it turns over......yup, carbs need some help , but the fact it turns over is very good!!
if it where me, i d pb blaster the plugs and drain plug and filter cover and bolt...do it outside,stuff rocks , but it stinks like hell inside..change oil and filter and lube ignition advancer....while youre in there, if it has points, check em out....i wouldnt be surprised if dad put in a dyna ignition, as he did the pipe, pods, inline filters.....can he give you any insight?....
i ll stay far, far away from any carb comments..:laugh: good luck and let us know how you make out.....with a few bucks and some hours, you could be tooling that puppy around the block in a month or so......
