trouble...
- rdgrnr
I removed the jugs on the 650 to fix an oil leak, and when I lifted it, sand that was trapped in between, fell into the crankcase. I am hoping this isn't cause for a complete tear-down...any words of encouragement?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- bountyhunter
- Thank you received: 337
I think dropping the oil pan to clean is a must on any major engine work to be able to rinse off the sludge layer you will find in the pan. You can also clean the garbage out of the oil pump screen.
IMPORTANT:
To clear out the solvent and prime the engine with oil before running, I would put in a decent motor oil and do a manual pump using the kickstarter. Pump it until your arm is dead and then drain it and fill with premium oil.
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- rdgrnr
I DON"T want to tear it down, so I'm liking the idea of dropping the oil pan and cleaning it that way.
The top is completely off, so rotating it by hand for lubrication will be no problem
As far as the clutch, it could use a good freshening anyway as it was slipping in 2nd and 3rd last fall. So this might be a good time to check the plates...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- KawiConvert
- Thank you received: 4
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- rdgrnr
Since it's tore down this far, I'm going to replace the drive chain, cam chain and guides, clutch plates, and also I want to beef it up a bit.
Should I just go with oversize, or would bumping it up with 750 parts be a good way to go? If I go with the 750, what parts will I need?
Any input is appreciated...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- Bluemeanie
- Thank you received: 14
- rdgrnr
You could swap in a complete (bolt in) 750 motor or install 750 jugs which will allow keeping stock 9.5 compression, 750 head (year depends on which type of timing chain your running) which has slightly larger valves along with the 750 cams which have slightly more lift and duration. It's the same as swapping in a 750 as the 650 and 750 both use the same bottom end. You could also keep your head and just use 750 cams. Decisions, desisions.....
How much would I gain by going with the 750 cams?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
