OK CRAP! Why is it doing this...?
11 Apr 2009 09:16 #280708 by Darkangel
OK CRAP! Why is it doing this...? was created by Darkangel
When the engine is running, it smokes a whole lot...plus when i turn it off...it makes a gurgle sound....Mind you I have just headers...No actual exhaust pipe...
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
11 Apr 2009 10:35 #280714 by franknsr
Replied by franknsr on topic OK CRAP! Why is it doing this...?
What color smoke?
Bluish whiteish is oil
black is running rich
white is coolant...means you have been drinking
Where is the gurgling coming from?
...and is it really gurgling or more like a quiet growling sound?
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
11 Apr 2009 16:26 #280756 by Darkangel
Replied by Darkangel on topic OK CRAP! Why is it doing this...?
blueish white color...but it's not coming from the exhuast...like from all around the engine...when i stop the engine and when its running....smoke just comes from around it...not like as if it was on fire...but she's smoke'n...I was wondering if the oil level was full...because I was stupid enough to fill it after I just shut it off...and the oil had not ran back down to the sight glass....But i dont know...
11 Apr 2009 16:32 #280757 by PLUMMEN
Replied by PLUMMEN on topic OK CRAP! Why is it doing this...?
is it blowing out the crankcase vent?B)
11 Apr 2009 16:55 #280761 by Darkangel
No i dont believe so...haven't seen any...
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
11 Apr 2009 18:11 #280778 by kzz1p
Replied by kzz1p on topic OK CRAP! Why is it doing this...?
Check your oil pump. What is the oil pressure? I had one do that once, you don't want to know what comes next. I hope, I am wrong.
11 Apr 2009 18:14 #280780 by Darkangel
NO...I dont want to know...TELL ME! lol....I am hope'n i just over filled the bike...
  • kzz1p
11 Apr 2009 18:17 #280782 by kzz1p
Check the oil level, then check the pressure. I don't want to be right, please prove me wrong. Does the motor feel real hot?
11 Apr 2009 18:21 #280784 by gane
Replied by gane on topic OK CRAP! Why is it doing this...?
DA, I would check oil level. With bike vertical after setting @ 3-5 minutes oil should be in middle of window. Bikes with worn rings will attempt to blow exess oil thru phlenum canister into airbox (if fitted) and gurgle as oil drains back into cases. hope this helps G
[img][/img] 1977 KZ1000A1
11 Apr 2009 18:23 #280785 by Darkangel
yes...your scare'n me....
11 Apr 2009 18:24 #280786 by Darkangel
After sitting...it's way past the sight glass....Guys...dont tell me i will have to tear this engine down...
  • kzz1p
11 Apr 2009 18:30 #280788 by kzz1p
DRAIN SOME OIL OUT.............................
