Camshaft mixup
- wiredgeorge
02 Mar 2006 06:04 #27505
by wiredgeorge
Replied by wiredgeorge on topic Camshaft mixup
That KZ750L3 page was well done (the link Duck posted). Just curious... how the heck does cam timing get set if there are no timing marks on the cams? You must have to pull them to adjust valve clearance as I bet the shims are under-bucket type.
- Duck
- e vica na i sau na ga
02 Mar 2006 08:59 #27536
by Duck
Replied by Duck on topic Camshaft mixup
WG-
I believe the timing marks are there. Look at the photo. One can almost make out an "EX" with a line under it. These sprockets look a lot like those in the 'J' and 1100.
-Duck
-Duck
- Meekrat
02 Mar 2006 21:23 #27749
by Meekrat
Replied by Meekrat on topic Camshaft mixup
Yes near the round hole there is a IN with a line under it, and further around the sprocket there is a Z7EX with a line under it.
From what I understand these are the marks that I will use to reassemble the alignment with the timeing chain. On the 46th link, again if im understanding correctly.
I can provide a better photo when i get the head back from the machine shop.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
03 Mar 2006 20:57 #28047
by 79MKII
The Kaw List:
Replied by 79MKII on topic Camshaft mixup
I've never seen the newer style cams, they are a bit different than the 73-80 variety. The common thread is that the older cams also have and "IN" and "EX" on the cam sprockets to differentiate the intake from the exhaust. That's always the easiest way to tell (except for the worm gear for the tach on older models). Glad you got it straight. The members of this site have helped me a lot too. Another happy ending!
The Kaw List:
