83 gpz head 77 650 engine
  • vach
  • vach's Avatar
Re: 83 gpz head 77 650 engine
27 May 2007 21:07
#144143
Doh!!
Post edited by: vach, at: 2007/05/28 00:12
1979 kz650 B. Chicago, Illinois
  • 77KZ650
  • 77KZ650's Avatar
29 May 2007 10:28
#144552
from my calculations,(they might not be bang on) a 810 kit with 650 head is about 10.8:1 vs 10.25:1 with the 750 head.
also APE Jay has told me you cant use the 30mm exhaust valves on a stock 650 valve seat. you can however use the intakes. you can get the 750 exhaust valves turned down to 29mm and then they will work. theres no point in going with a bigger valve if the seat cant be opened up enough for it;)
07 MDP Rookie of the Year
