- Thank you received: 5
Leak Down Test questions
- cnyl
It's got 50,000 miles and i'm looking to get some more life out of it.It does run good but smokes a little.. Kinda blackish in color. I installed new Dyna coils, cables, spark plugs, carb rebuild & sync. There is a noticeable "high pitch" ticking sound coming from the top end near the #1 cyl. It's not constant though..Kinda sporadic. It doesn't sound like loose valves or like it needs a valve adjustment. Maybe a wrist pin?
I pulled the exhaust, noticed the exhaust gaskets were gone. I looked into the exhaust ports they are all carboned up but the #1 also had wet oil around where the valve comes through. Seal?
I wanna do the right thing and not just throw money at it.
Sometime in the future i'd like to do a big bore kit on a different engine.
Any advice on what to do first?
Thanks
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
- Thank you received: 2098
It's real easy to miss seeing an old sooty flattened gasket crusted up inside the exhaust port. And sometimes there are two old gaskets in there.
Good Luck!
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
Some of these places are pretty decent about having on hand an assortment of test tools for loaning out to customers.
Good Luck!
That alone might improve the compression and engine performance.
Good Luck!
- mehall2
'81 KZ550 LTD
'07 Yamaha FZ6
- timebomb33
- mtkawboy
- Thank you received: 16
- cnyl
I have the service manual and i'll start checking the valve clearances tonight. Will a leak down test tell me something that a compession test will not?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
- mark1122
- Keep twisting it
- Thank you received: 109
if u do this on a fresh motor u will have a baseline # (say 5%)as your motor wares u can monitor its presure loss.I made my own. u just need to epoxy the pathway from gauge#1 to #2 closed, then drill it out again @ .040".
Here is a pic of a factory made unit.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- modprod
Thanks guys.
Yes, if you have leakage it will be audible where it's coming from.
- gane
[img][/img] 1977 KZ1000A1
