- Thank you received: 1
low compression
- gane
29 Jan 2009 19:24 - 29 Jan 2009 19:32 #260900
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic low compression
D, Copper head gaskets and steel o rings became popular thru neccessity for turbo's and big bore/high compression motors. and went hand in hand w/heavy duty cyl studs. stock head gaskets w/mild motors were seldom problem. as they are forgiving. copper head gaskets can be used without ringing if compression is moderate, and be re-used (after annealing) if you plan on being there often. since your' going there, would staight edge and or plate head, and staight edge cyl. before disturbing cyl if possible, (once base gasket is disturbed it's false ecconomy to short-cut. I like stock, Others should chime in.G PS this would also be a good time to Barrett (SP) head.It might aide compression issue. (IE the possibility of a gpz/other head.) Luck G
Last edit: 29 Jan 2009 19:32 by gane.
- timebomb33
- Thank you received: 10
30 Jan 2009 21:47 #261029
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic low compression
your problem really sounds like cam timing still. i definitly would start there and double check that first it would not be the first time that problem has occured it happens to the best of us. i doubt that it is a deck height problem and depending how pitted the valve seats were pitted can have an effect on how far your cylinder head guy had to sink the valves but he should have tipped them a bit to bring them closer to the middle of the range.
- Old Man Rock
- Thank you received: 225
31 Jan 2009 04:48 - 31 Jan 2009 04:52 #261081
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic low compression
Dshelly...
Timing diagram as provided in the image, doesn't require a degree wheel for this, only observations and possible resetting to the 28th tooth on the Intake camshaft compared to the exhaust camshaft mark aligned with the head deck...
Would be best/easiest to remove the tank but popping off the valve cover is only required for observations...
NOTE: Before doing so, get a new valve cover gasket!
NOTE2: Remove cylinder #4 spark plug... Remove ignition plate cover. Rotate the large 17mm nut forward until you can see the #4 piston at it's highest level. Will be close to TDC.
While the cover is off, check your shim to cam lobe heights... Kawi spec is .05mm - .1mm... As provided to me, shoot for .04 to .06mm....
Continued by strobe light, points setting (unknown if you have EI) etc....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 31 Jan 2009 04:52 by Old Man Rock.
- bountyhunter
- Thank you received: 337
31 Jan 2009 13:44 #261169
by bountyhunter
Replied by bountyhunter on topic low compression
Old Man Rock wrote:
Removing all spark plugs will make it a whole lot easier to turn with that crankshaft nut.Dshelly...
- timebomb33
31 Jan 2009 13:50 #261170
by timebomb33
that is an awesome diagram i've never seen one that clear yet. geez's OMR you sure are a good drawwer.
- mark1122
- Keep twisting it
- Thank you received: 109
01 Feb 2009 13:49 #261543
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic low compression
sounds like the cam sprocket may be off by a tooth.
Also i would try a dif comp gauge just to verify that yours is reading correct. could air be leaking around the gauges threads?did u have the throttle wide open?
A stock head gasket is best. copper will leak sooner.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
