Who's the expert on pistons? Pistons with holes!
- IA_Cuban
Can I link to an existing thread on another forum? Let's see...
www.intruderalert.com/cafe/index.cfm?page=topic&topicID=144894
That's a thread I started at my normal home 'IntruderAlert.com' (a shameless plug) after my son-in-law's little KZ-550 had an 'issue' on a ride back from Nova Scotia. The pics are actually hosted at...
s179.photobucket.com/albums/w310/IA_Cuban/Technical/
Any relevant information would be greatly appreciated. I'll try my best to answer any questions. I do know my way around a toolbox...
Thanx!
Cheers!
1980 KZ-550
- 77_650B1
Since your valve looks ok, lean cond then detonation is the most likely culprit. Was the carb syncing connection left off on that cylinder? Main jet plugged?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- IA_Cuban
Cheers!
77_650B1 wrote:
With what you said over there, I'd have to say serious lean condition causing her to run very hot, melt the piston, and then detonate, blowing it up. A couple guys on intruder alert said coolant, thats obviously not it on an aircooled engine.
1980 KZ-550
- RollingStock
thats what happen to my 1000.
let me know if u guys need any 550 motor parts.. i got a whole motor that i would love to get out of my way(its already been taking apart)
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- wiredgeorge
- IA_Cuban
droped a vavle?..
:ohmy:
What the hell am I looking at? Is that the top of a piston? Our valves are still in place. Thanx for the kind offer for the engine components. I'll keep it in mind!
77_650B1 wrote:
Maybe his burning more gas is because that cylinder wasn't making any power, so he needed to crank her a bit more to get the revs. Something must have been going on to allow a bunch more air into the cylinder.
Agreed!
wiredgeorge wrote:
The most common reason that a piston is holed is that fresh air is being drawn in and focusing on the piston crown. This is normally because the carb holder seal is bad or the carb holder is cracked. You didn't mention if the bike has the stock air box or pod air filters but the plugs were pretty lean looking; especially 2 and 3. This may be due to jetting but more likely, a major air leak. Also make sure that any vacuum fittings are either capped or connected.
Thanx. Yeah, the airbox was removed before we got the bike, there are 4 new cone shaped pod filters (not K&N's) that we got from eBay on there now. Honestly, the bike was running pretty damn good, until this. Oh, those spark plugs you see @ photobucket are from a Honda V45 Magna. I don't have a reading for the little Kawasaki. Wish I did. I'll double check the carb holders. I know the vacuum fittings are still capped, but I'll have a good look...
Cheers!
1980 KZ-550
- steell
I don't believe that was caused by detonation, I believe that was caused by the cylinder overheating and the rings seizing to the cylinder walls, thus ripping the ring lands off the piston. Look at the sharp edges of that piston, that hole was made by fracture, not melting.
A lean mixture may very well be the ultimate cause of the overheating condition, but detonation didn't do that to the piston.
- Old Man Rock
- Thank you received: 225
Ok, I've got to ask the stupid question here....
To accomplish the severity in those images (holes/melt down) to that level, am I wrong in thinking there would be some tell tale sign that things weren't right?
I mean hollyshit, extreme pinging, grinding noises, running like crap, smoke, loss of compression something.... :blink:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- keith1
Holly Crap!
OMR
i was thinking the same thing....even at highway speeds with/without a brainbucket,something would have made enough of a racket to signal the riding party
that something was rotten in denmark....
- wiredgeorge
