Removing carbs off an '81 KZ550 ltd
11 Dec 2008 09:23 - 11 Dec 2008 09:24 #251975 by mehall2
Removing carbs off an '81 KZ550 ltd was created by mehall2
Hello, I just picked up an 81 KZ550 ltd as a project bike really cheap. The engine would not go past top dead center and I'm currently pulling it apart to see what damage, if any, there is. There are many good parts on this bike so the worst case scenario is that I could get my money back and more if I parted it out. I'd rather ride it though! So here's my question - I'm at the point where I need to take the carbs off so I can pull the head off to inspect things. Even moving the airbox back as far as it can go, I'm not seeing enough room to get the carbs off the engine head. I don't want to break anything so any hints and tips on pulling them off would be appreciated. Have a pic for those interested.
Cheers,
Mark
'81 KZ550 LTD
'07 Yamaha FZ6
Last edit: 11 Dec 2008 09:24 by mehall2. Reason: uploading pic
11 Dec 2008 09:31 #251976 by harm
Replied by harm on topic Removing carbs off an '81 KZ550 ltd
Welcome to the site!
The carbs are in there pretty tight but they will come out. The rubber boots on the back side of the carbs have probably hardened and over time, these will need to be removed. I usually try to collapse them and push them inside the air box, then you pull the carbs out of the front rubber mounts and bring them out the side.
Hope this helps!
Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
11 Dec 2008 09:36 #251978 by ds390ss123
Replied by ds390ss123 on topic Removing carbs off an '81 KZ550 ltd
Disconnect the boots from the back of the carbs then without putting holes in the boots push each (one at a time) past the intergrated flange back into the air box. You might have to take the air filter out. This should give the room needed. be ready to fight it a little just take your time and dont lose patience.
11 Dec 2008 09:51 #251979 by MFolks
Replied by MFolks on topic Removing carbs off an '81 KZ550 ltd
Try using a hair dryer to soften up the boots. They have hardened from exposure to ozone and will be difficult to flex while cold.
11 Dec 2008 09:58 - 11 Dec 2008 10:01 #251982 by Patton
Replied by Patton on topic Removing carbs off an '81 KZ550 ltd
While at it, may wish to also consider new soft pliable air intake hoses from Z1 Enterprises.
Here's the link to click >
Z1E
Good Luck! :)
Last edit: 11 Dec 2008 10:01 by Patton.
11 Dec 2008 10:52 #251985 by mehall2
Replied by mehall2 on topic Removing carbs off an '81 KZ550 ltd
Thanks everyone for the great suggestions. As soon as I get a chance I'll give that a try.
'81 KZ550 LTD
'07 Yamaha FZ6
11 Dec 2008 14:55 - 11 Dec 2008 15:01 #252024 by loudhvx
Replied by loudhvx on topic Removing carbs off an '81 KZ550 ltd
Yup, hair dryer definitely helps.
1)Loosen the bolts holding the airbox in place so the airbox can move backward (it only moves slightly).
2)Make sure the carb holder clamps are super loose or better yet removed. (The carb holders have to open and deform a lot when the carbs are being pulled.)
3)Roll the spring clamps back to the air box.
4)Heat the airbox boots and carb holders with a hair dryer for a few minutes till they seem soft.
5)Sit on the bike and pull the carbs back towards the airbox.
6)Wiggle the carbs up and down as necesary.
7)Then tip the front up or down after they clear out of the front holders.
8)Then move them forward to clear out of the airbox boots.
9)Now they should snake out sideways.
Last edit: 11 Dec 2008 15:01 by loudhvx.
11 Dec 2008 15:03 #252028 by mehall2
Thanks for tip guys. They worked although I had to do some tugging to get the carbs off the header. The tip on getting the clamps super loose was the ticket. Now for the bad news. looks like I have damage to the head, valves and 2 pistons have holes through the top. I think my cylinder walls might be scratched up pretty good also. I think I want to puke. Would an '83 KZ550 GPZ motor work in an 81 KZ550 LTD frame? I see one on ebay.
'81 KZ550 LTD
'07 Yamaha FZ6
11 Dec 2008 17:17 #252068 by keith1
Replied by keith1 on topic Removing carbs off an '81 KZ550 ltd
hang in there....lots o help here...good luck....
11 Dec 2008 17:46 #252075 by loudhvx
It will bolt in, but there are some issues. First, there is the oil-cooler which will need to be mounted to the frame somewhere.
Then there is the carburetor issue. The Carb holders on the old LTD engine will have to be modified and installed on the GPZ engine. The carbs will have to be rejetted also.
11 Dec 2008 17:52 - 11 Dec 2008 18:04 #252080 by loudhvx
delete this please
Last edit: 11 Dec 2008 18:04 by loudhvx.
11 Dec 2008 18:03 - 11 Dec 2008 18:25 #252082 by loudhvx
I see an LTD motor. Kinda steep at $150.
And two others at $99. One looks real clean.
The 82 gpz (82 kz550H1) motor seems very steep at $350, and it looks pretty rough.
I Can't get the links to post here for some reason. :angry:
Last edit: 11 Dec 2008 18:25 by loudhvx.
