- Thank you received: 2
best oil filter??/
- keith1
back in my younger years and during college i worked at quick-oil change places and then the five years in the Chrysler shop and the Harley shop, i can safely say i have changed oil probably thousands of times. Fram are the lowest quality filter out there, and i tend to group most others as the same, (pretty good) quality. for all my junk i just go buy the factory stuff, Jeep and the Dodge get mopar, the Harley=Harley, BMW gets BMW, Kawasaki gets Kawasaki on down the line.
I have to say that the grippy stuff that Fram puts on the end of the filter was a darn good idea.
yup it was and is, but it doesnt negate the inferior inards...the ad target...the guy who is basically clueless , but can pull off the weekend oil change to impress junior ....."look son, see that grippy black patch, thats the sign of a good workable filter...ive always used fram and so did grandpa......"........:laugh: .....keith
- bountyhunter
- Thank you received: 337
That's why I bought the Fram filter: it's the only one I could find that came with O rings that fit my bike. My dealer said the O rings for the old 750 twins were not available from kawi, maybe he was just blowing me off.One benefit with the Wix filters I get is that both of the o-rings come with them. The Kawi filters I used to buy did not. Dealer wanted an extra $8 for them.
If there is a better filter/O ring available for the old 750 twins I would use it. Is there a site that shows the listings for the Wix filters?
- oldcoldankles
www.wixfilters.com/filterlookup/index.asp
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
www.calsci.com/motorcycleinfo/Filters.html#OilFilters
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- loudhvx
- Thank you received: 1616
Purolator ML16812
STP SMO-12 (Same as Purolator)
Baldwin: P148
Emgo: 10-37500
Hastings: LF571
Honda: 15410-422-000
Honda: 15410-422-004
Honda: 15410-426-000
Honda: 15410-426-010
Honda: 15410-300-024
K&N: KN-401
NAPA: 4941
Purolator: ML 16812
STP: SMO-12
Triumph: 1210031
Triumph: 1210031T301
Wix: 24941
Yamaha: 36Y-13441-00
Perf-Form: J-501
I AVOID THESE FILTERS MADE BY THE SAME COMPANY AS FRAM FILTERS:
avoid Fram:CH6012
avoid Pennzoil
avoid Penske
avoid Castrol
avoid Quaker State
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- pstrbrc
- '81 GPz 1100 project
- Thank you received: 9
Yeah, I've heard stories about Fram filters. One speculation I've read is that the failures seem to be based on moisture in the oil. If you live in a dry climate and always thoroughly warm up your engine it seems that you have a much smaller chance of a fram filter failing. But why take the chance?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
