My Bike Backfires during high RPM Deceleration
- Stevec6535
14 Nov 2008 14:40 #247399
by Stevec6535
My Bike Backfires during high RPM Deceleration was created by Stevec6535
Hey
Im hoping that somebody out there could help me out. I have a 1981 Kawasaki KZ750 4cyl. The Bike has a Dyna 2000 Ignition system, Vance & Hines 4 into 1 Exhaust, K&N Intake pods, New intake manifolds DynoJet carb rebuild kit as per Vance & Hines recommendations. New Spark Plugs, and Plug Wires. New Tank, Fresh Fuel All NEW Parts but when I make a high speed pass or throw a High rev it back fires on the deceleration end of the rev and at night you can see it spit fire out of the tail pipe. If I hold a steady high RPM it runs fine but it back fires when I let off the gas. The bike starts right up and idles perfect. Any suggestions on what could be causing the back fire would be a great help
Thanks
Thanks
- mark1122
- Keep twisting it
- Thank you received: 109
14 Nov 2008 15:26 #247405
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic My Bike Backfires during high RPM Deceleration
Have u done a plug chop at full throttle yet?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
14 Nov 2008 16:05 #247412
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic My Bike Backfires during high RPM Deceleration
it sounds like your main jets are probably to lean by a bit try going up a size or two.
- HerrDeacon
14 Nov 2008 16:51 #247422
by HerrDeacon
Replied by HerrDeacon on topic My Bike Backfires during high RPM Deceleration
Mark, when doing a plug chop how long to you need to run it at a certain RPM? If testing full throttle, how long do you need to run it like that? Same for idle, and crusing, how long?
- timebomb33
14 Nov 2008 17:42 #247431
by timebomb33
put fresh plugs in and give your self a good distance of run and shut down area i usally do it at a drag strip. make your run then pull the clutch and kill the ignition at same time keep the clutch pulled in and stop with either the brakes or coast to a stop. pull the plugs and check them out.
- gane
14 Nov 2008 21:23 #247478
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic My Bike Backfires during high RPM Deceleration
Steve, Backfires on de-cel can have many causes, But the most common on otherwise good running bikes, are the coupled effects of lean fuel/air mix when slides drop and close needle/nozzles, and most of main jet path. this and a less restrictive exhaust, cause a mix too lean to either ignite or fully burn before it enters exhaust, where surrounded by other hot gasses,it does ignite. a situation I see regularly on cruiser twins w/loud pipes. Raising needles/ increasing mains usually help.Plug chops are good, tho mastery of reading is almost a forgotten art. others will correct me If I"m wrong, but a couple of farts on decel are no cause for alarm, tho a machine gun chatter should be addressed if for no other reason than wear &tear on exhust/baffle (if it exists) G
- MDawnz1
- Thank you received: 27
14 Nov 2008 22:07 #247484
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic My Bike Backfires during high RPM Deceleration
Easy one ,,,
You have AIR getting into your exhaust ,
probably right by the head.
No air no backfire ,,
It just can't burn without fresh air.
Doesn't matter if your carbs are off, if they are.
Fuel CAN'T burn without air.
1974 Z1a, still 903
- Stevec6535
15 Nov 2008 12:01 #247559
by Stevec6535
Replied by Stevec6535 on topic My Bike Backfires during high RPM Deceleration
What is a Plug Chop?
- timebomb33
15 Nov 2008 12:10 #247562
by timebomb33
the same symptoms will occur if the main's are a bit lean. a plug chop is done to verify jetting changes if you guys want to know more about them go to ngk's website.
- Stevec6535
15 Nov 2008 18:41 #247629
by Stevec6535
I Fixed it. Since I am running individual air pods and a Dyna 2000 Digital ignition, there is no air box (no smog control) or mechanical vacuume advance. there are 2 rubber air injection lines that go into the top of the cam cover on the top front engine for the US model. These 2 air injection lines are for smog controll, but when you get rid of all the smog controll, it will suck cold air in through the canister under the tank. I blocked off the inlet for the smog canister and the bike runs WAY better and has no backfire what so ever. My manual shows that the UK model of this same bike dosent even have the injection ports on the cam cover. Thanks for all of the advice. I hope this will help some one who is having the same issue I was.
- timebomb33
15 Nov 2008 18:43 #247630
by timebomb33
canadian models don't have it either so it must have something to do with california emissions.
- Stevec6535
16 Nov 2008 10:38 #247742
by Stevec6535
Yeah, in the haynes service book it claims that it is on US modles only.
