How to: Valve-stem carbon removal?
- onanysunday
09 Oct 2008 11:03 - 09 Oct 2008 11:04
I pulled the exhaust pipes off my KZ1000E-1 to change the oil a few weeks ago. I peered into the exhaust ports and noticed there appeared to be a lot of carbon surrounding the valve stems. Is there any easy way of de-carbonizing this? Any miracle formula? So far I've used Chemtool and Seafoam, thinking this stuff would help but they haven't done much. I know there are a lot of over-the-counter "supposed" solutions, but do any of them actually work for cleaning this hard-to-reach area? the width of the valve stem appears to be doubled because of the carbon blanketing the stem. As it stands now, does this add weight to, or retard valve operation? Thanks.
Note: This is not my valve, mine is actually carboned up to about TWICE the width of the valve stem.
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
Last edit: 09 Oct 2008 11:04 by onanysunday.
- BSKZ650
Re: How to: Valve-stem carbon removal?
09 Oct 2008 11:24
wire brush on a bench grinder, best , fastest way to do it
77 ltd1000, current rider
76 kz900, just waiting
- onanysunday
09 Oct 2008 11:31 - 09 Oct 2008 11:36
Do you know of any solutions that wouldn't involve disassembling the cylinder head or braking head seals? Ideally, that would be the best solution; but are there any others that wouldn't be as time consuming, costly, and involved? What about pouring some kind of solvent down the spark-plug hole and turning the engine over, allowing it to sit and de-carbonize for awhile?
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
Last edit: 09 Oct 2008 11:36 by onanysunday.
- krazykat
09 Oct 2008 11:55
I'd suspect that kind of build up is burned oil from a leaking valve stem seal.
Pouring solvent down the spark plug hole and letting it sit isn't going to do antyhing for the valves. If it gets past your rings it'll contaminate the oil too.
77 KZ-750 ~10k original miles and a few tweaks
- onanysunday
09 Oct 2008 12:44 - 09 Oct 2008 13:08
Yeah, you're right. It would contaminate the oil. Best to do this right before an oil change, but why wouldn't it clean the valves? If I were to pour in a couple ounces and "kick" the engine over a couple times it seems like Berryman's Chemtool? could start going to work. Hmm.. Your guess is as good as mine.
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
Last edit: 09 Oct 2008 13:08 by onanysunday.
- fixer5000
09 Oct 2008 13:08
i think the berrymans would take out any rubber or plastic it hit...i wouldnt do that
1978 kz650b pretty much stock
massachusetts
massachusetts
- BSKZ650
09 Oct 2008 13:39
berrymans will make the seals soft, there is no way to do it without tearing it down.
if you put something in it to let it soak, you will dillute the oil, and it will take several changes to get it out, and may bamage the clutch and rubber parts inside the engine.
- PLUMMEN
09 Oct 2008 19:51
spraying in a little water in the carbs while cracking throttle open is good for cleaning carbon off pistons and combstion chambers.
- Sandy
- Fly High,Tony
09 Oct 2008 21:13
PLUMMEN wrote:
With,or WITHOUT vinegar?:laugh:
1977 KZ1000 A-1
- PLUMMEN
10 Oct 2008 04:12
i guess it would give your motor that fresh feeling !:S :laugh:
- BeeSting
- Drive it like your tax dollars already paid for it
10 Oct 2008 04:49
With any means besides disassembly I'd be concerned with any harder deposits going down into the combustion chamber. The only other thing I can think of if you wanted to minimize downtime is to get another complete head, work it over and clean it up, and then do the swap.
Overhead cams have given me nightmares before, one of the reason why I've sold off some good BMW cars for cheap. I'm not looking forward to it.
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
Christine
- onanysunday
10 Oct 2008 08:46
Plummen- Spraying water down the carb throats will remove some carbon? How much do I spray? Until it bogs down? Spray on a warm or cold engine?
79 KZ1000 E-1
VM28SS
K&N Pods
VM28SS
K&N Pods
