- Thank you received: 80
Z650 B1 cam chain idler wheels
- OnkelB
17 Feb 2006 14:22 #24531
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Z650 B1 cam chain idler wheels
No problem, I have an interest in it myself, getting ready to reassemble a 650 engine.
There is some related information about the cam chain tensioner here.
- lama7
23 Feb 2006 02:14 #25806
by lama7
Replied by lama7 on topic Z650 B1 cam chain idler wheels
Thanks everyone for all your responses.
I also got hold of some Z1000 cam wheels and compared them to my Z650 ones and found no significant differences, and so have decided to use them.
It has been sugested to me that the aftermarket, totally metal cam wheels are likly to be very noisy, and that the rock hard rubber on used genuine onews will soften up at operating temperature, so helping the engine run quieter.
Does onyone have experience with the totally metal type, were they much noisier?
- OnkelB
23 Feb 2006 07:43 #25869
by OnkelB
I have no experience with the totally metal type. I checked Z-Power in UK, they have two different idler gears available, the original 12057-002 (95£)and an aftermarket one called "pattern" 12057p-Z (48£) - is the latter the totally metal type you´re referring to? In the pic below the aftermarket type is to the left, the oem type to the right, would be interested to hear about the differences.
Post edited by: OnkelB, at: 2006/11/20 16:48
- lama7
24 Feb 2006 00:43 #26065
by lama7
Hi OnkelB,
Yes, the Z-Power pattern wheel is the one I was refuring to, APE do something similar too.
The shoulder that the edges of the cam-chain side plates rub on are rubber couted on the Kawasaki part.
If the pattern part has no rubber here, so if the chain still makes contact on this shoulder it could, I guess make it much noisier
- OnkelB
24 Feb 2006 04:40 #26075
by OnkelB
Ok, thanks - thought there had to be a reason for the pattern ones to be half the price, guess that was it.
