when to weld a crank?
- School Teacher
15 Sep 2008 21:20
900 crank, 1075kit, 435 under bucket cams, ported head, 29 0r 33 mikunis
asking for trouble? not running a slick and mostly street driving.
thanks
thanks
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- donthekawguy
Re: when to weld a crank?
15 Sep 2008 23:28
You should be alright without welding it. If you plan on splitting the cases I would do it or if you plan on running a wide tire.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- PLUMMEN
16 Sep 2008 05:18 - 16 Sep 2008 05:32
let me get this straight!900 crank,1075 kit,worked over head and 435 cams .... and youre not going to abuse it???? ;)weld the crank!
Last edit: 16 Sep 2008 05:32 by PLUMMEN.
- wiredgeorge
16 Sep 2008 05:53
I bet he told his wife he wanted to ride his bike to work every day and to make it reliable he needed to spend a few bucks to rebuild it... 1075 kit/cams hehehe IF you have the engine out, weld the crank. ONLY certain types of people put a big bore kit and cams in a KZ and those people are the type who need to weld their crank. I have bent crank shafts in the past and it was from drag racing and missing a shift and over revving. Missing a shift can happen on the street pretty easy. This was on a Suzuki GS1100 (well it was 1260cc by then with cams, etc. This was needed because gas prices had gone up and I needed to make the bike reliable for daily riding... right honey???) hehe
- FastKaw1
16 Sep 2008 08:47
Don't mess around. WELD IT...
It pays it the long run.
XENU
XENU
- mtkawboy
16 Sep 2008 10:05
My 1105 was built by Superbike Mike a prostock racer from years back in 1977 as a street motor for a buddy. He got into Harleys and gave it to me. Its been running for 31 years unwelded. That said if I did it myself I would weld it. I dont run it that hard but at times I beat the crap out of it. It still runs pretty good for an old dog
- racer54
16 Sep 2008 15:59
You would be able to get by without welding the crank as long as you don't abuse it. Having those parts doesn't necessarily hurt the crank but what you have to watch out for is if you are abusing it and the tire hooks. That is what will getcha! If you have the oppurtunity, get it welded just for insurance sakes. Doesn't cost much and once welded, you can stretch those cables ALOT, and it will be fine. I personally would weld it just to feel safe though. That's the first thing I do whenever I build a motor.
- darmahsd
20 Sep 2008 12:22
If I went to a big bore kit on my '84 1100 GPZ over the winter, I would go with the conventional wisdom and have the crank welded.
Need advice. With 30 thousand miles, the bike has been a good runner since new. Once, many years ago, I started it up from winter storage and from cold, it reved sky high until I could react and find the kill switch. Turned out the throttle cable somehow froze itself in the wide open position somewhere down close to the throttle butterflies. I was lucky 'cause it never seemed to effect anything but I was never comfortable knowing it happened. So, having said that, it seems just not enough to weld it.
Which outfit do you recommend me sending it to that will check the alignment first to make sure none of the cheeks are askew, and at the same time, check all the rollers? How about a complete blueprint, where I would send out all the new overbore pistons to be balanced with the crank after it is welded?
Thanks for any recommendations.
Stephen
Stephen
- wiredgeorge
20 Sep 2008 16:35
Falicon is probably best known for crank work. I think they are in Florida. I spent a bunch of money with them when I was young and stupid. I suspect there are folks right here on this site that could do this work... perhaps one of them will speak up. I don't know about blueprinting a street crank but its your money...
- darmahsd
21 Sep 2008 10:51
Yep, 'forgot about them. Thanx George. They even give a price list. To balance and weld is VERY reasonable. Even a full tilt crank is under a grand.
Googled for website. Great!
Stephen
Stephen
- trippivot
22 Sep 2008 07:55
when in doubt always weld the crank!!
pierson, falicon, gary clark, will cost multiple hundreds and into the thousands if you get: rods, bead blasting,polishing , knife edging.. etc... cryogenic trating...
we have a shop locally that will reference and weld for $200.00.
- School Teacher
22 Sep 2008 08:18
if you know how to weld what does it take to weld a crank? how do you get to the inner pins? stick weld it?
1980 kz1000G1
1980 kz1000G1
