Problem, is it intake reversion?
  • trippivot
  • trippivot's Avatar
Re: Problem, is it intake reversion?
12 Oct 2008 09:58
#241432
just a little bit by hand with the rotary cutter.
after we found the 17mm pin was the same then the piston height WOW we have a match!!
a set of worn out 1015 bores honed right up
dr. franken bike here.
  • PLUMMEN
  • PLUMMEN's Avatar
12 Oct 2008 20:22
#241515
Old Man Rock wrote:
Hey Plummen, sell them KZ door stops on e-bay. LOL!
Hell, those people will buy anything no matter how ridiculous or costly.
OMR
i swore off porting heads after the last one turned out reasonably well,i figured it was a sign from above to give up!:laugh: anybody who can understand all that techno stuff is way out of my league!onthe other hand i can Plumb,wire,tin and work onfurnaces and a/c's better than any engine builder i know,i just know my limitions after many sideways trips into the wall!:laugh:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
13 Oct 2008 06:43
#241548
Thats cool.B)
what did the compression ratio end up as?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
13 Oct 2008 06:54
#241551
Thats cool.B)
I was thinking the same thing. I think I HAVE a set of Yamaha 1100 pistons around here...I love Frankenstein motors.
You shoulda seen my last low buck Ford stroker motor, before I got out of cars.
Build Thread
  • fast_johnny
  • fast_johnny's Avatar
16 Oct 2008 18:29
#242175
I believe it's just the carbs. I bought a set of those from Wired George and he warned me that they do exactly that, stumble at WOT. I live with it because once it's done stumbling, I'M GONE!!!
Try some different carbs if you have them. May be easier than pulling it all apart again.
Good luck!
1977 KZ1000A1 1075cc, Kerker, Cavanaugh Head, RS34s
1995 KZ1000P
  • Exitpupil
  • Exitpupil's Avatar Topic Author
19 Oct 2008 13:26 - 19 Oct 2008 13:28
#242667
I would never buy a set of carbs if from someone that told me they would not work properly. After much tinkering I got it tuned out. A stumble is unacceptable to me. If that's the case while you are stumbling someone with well tuned STOCK carbs just ate your lunch!
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Last edit: 19 Oct 2008 13:28 by Exitpupil.
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
22 Mar 2014 14:02
#626143
This needs to be seen and read again
