Epoxying up the port floor is nothing new. Motoman certainly didn't invent it. He simply advocates it's use. In some situations, there are benefits, in other situations it just plain doesn't work out.
I probably missed out on some flow from lack of a multi angle valve job. My head only had 4000 original miles on it so I just lapped the valves good. Maybe this winter I'll get the valves done professionally.
It's always the guys that want too big carburetors that end up having stumbles and weak midrange acceleration problems...I've seen this time and time again for over 25 years.
C
larrycavan wrote:It's always the guys that want too big carburetors that end up having stumbles and weak midrange acceleration problems...I've seen this time and time again for over 25 years.
C
Thanks for the data and it is understood, but first to clarify about carb/part selection:
Mikuni (the manufacture of the RS series carbs) recommends the RS34 for 750CC engines. It is the smallest carb they make that will even fit on a KZ. They actually recommend 36mm carbs for the KZ900-1100. Exitpupil is running BS34 constant velocity carbs on his engine. These carbs came STOCK on all J model KZ1000s. So I don't agree that we've overcarburated.
The main idea behind the high velocity port theory is this: The extremely high air flow velocity at the choke point (which shows up as a restriction on the flow bench) is actually responsible for "charging" the cylinder at the end of the intake stroke when the piston is rising in the cylinder and before the intake valve closes. Without this ram-air effect at the choke point, the piston will push air out of the cylinder and back into the intake port causing loss of volumetric efficiency and positive pressure pulses (reversion) in the port. This is especially true during low and mid-range RPM when port velocity is relatively low.
Larry, you mentioned a side-by-side comparison of engines with different porting methods and carbs, which I think is a great idea...Maybe this is the beginning of an annual KZ street and strip shootout...
back to the bike heads, what have you seen with just cleaning up the rough edges in the ports, is it worth the time and effort on a street motor?
