engine smoking
03 Aug 2008 19:16 #229968 by pinhead
engine smoking was created by pinhead
Ok, I have a 1980 kz1000 limited that is smoking a lot out of the exhaust. I have replaced the rings and the head gasket and it still smokes. The valve seals are all new too. I cannot seem to figure out why it smokes. It is in the #4 cylinder. I have made sure the bottom triple ring is installed correctly. I have done a compression test and all have the same compression. I am lost at this point. Can someone help me.
03 Aug 2008 19:59 #229985 by PLUMMEN
Replied by PLUMMEN on topic engine smoking
color of smoke?was it smoking on same cylinder before rebuild?possibly some old oil in exhuast pipe?;) need more info
04 Aug 2008 04:37 #230019 by pinhead
Replied by pinhead on topic engine smoking
It was smoking before rebuild. It is oil smoke (white). It could be oil still in exhaust. There is a lot in there. I just didn't know if that could cause that much. Should I see if I can clean that out or should I just run it down the road a little bit and see if it goes away. I really hate the thought of pulling the engine apart again.
04 Aug 2008 04:39 #230020 by pinhead
Also, the #4 spark plug is getting oil fouled again. So I guess it's not just the oil in the exhaust. I guess I need to check the valve seals again. They looked good.
04 Aug 2008 05:20 #230021 by FastKaw1
Replied by FastKaw1 on topic engine smoking
When you get the head off, make sure the head is not cracked between
the spark plug hole and the exhaust valve. (not always easy to see)
Make sure the head is not warped. (also not easy to see.)
Before you take it apart do a leak down test. That should tell witch
cylinder might be giving you a hard time.
XENU
04 Aug 2008 05:27 #230022 by BSKZ650
Replied by BSKZ650 on topic engine smoking
There is a possiblilty of a broken ring, I have done that myself during a rebuild,
77 ltd1000, current rider
76 kz900, just waiting
04 Aug 2008 08:57 #230069 by pinhead
Ok, I drove it up and down the road a few times and it was just oil in the exhaust left over from before. Problem fixed. Now to just get rid of a couple of oil leaks and I'll finally get to drive.
  • mark1122
  • Keep twisting it
04 Aug 2008 15:02 #230158 by mark1122
Replied by mark1122 on topic engine smoking
pinhead wrote:
Ok, Now to just get rid of a couple of oil leaks and I'll finally get to drive.
Are all the covers leaking? Mine did .I now use atv silicone on them. it works well. Easy to clean off later too. If your motor is black buy black silicone. Put it on sparingly; cut a small hole in the tip to apply it sparingly. Remember it will sqeese out a bit abd u can wipe it off. But what squeezes in stays in. u don’t want big gobs going through the motor. Both sides of the gasket. Then snug the bolts lightly until it dries then retighten them. Good to go.
ALSO
Retorque the head bolts 1 at a time(loosen 1 then retighten it) IN THE PROPER TORQUE SEQUENCE.
Good luck.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
05 Aug 2008 06:23 #230269 by wiredgeorge
Replied by wiredgeorge on topic engine smoking
Before getting excited AFTER A TOP END REBUILD about smoke, let the rings seat in. When I assemble an engine, I generally use too much assembly lube and this takes a while to burn off as well. If it still smokes after 500 miles or so, then track down the reason.
06 Aug 2008 10:00 #230508 by monkonmonk
Replied by monkonmonk on topic engine smoking
Not to hijack, but what is the proper torque sequence for the valve cover?
Thanks
  • mark1122
  • Keep twisting it
06 Aug 2008 10:38 #230514 by mark1122
Thanks
HEAD BOLTS.:)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
06 Aug 2008 11:49 #230524 by bountyhunter
Replied by bountyhunter on topic engine smoking
When I finished putting mine back together late one Sunday night, I fired it up and it was smoking like those old trucks that used to drive down the streets in Louisiana spraying that plume of DDT to kill all the mosquitos. We used to get on our bikes and ride through it....
The engine smoke cleared up after about five or ten minutes of running, but it was terrible at first.
