No valve clearance!
- jmargrav
1982 KZ750-E3
Lariamie Wyoming GO WYO!
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- RonKZ650
- Thank you received: 240
- Sandy
- Fly High,Tony
- Thank you received: 13
I can't remember how much was removed,but yes,that's what you have to do.
I also had the keepers shaved off a bit too,to keep them from bottoming out.
What really pissed me off,was that I had sent my whole shim supply with the head,and I explained to the manager of the machine shop about the clearances,but I still had that issue.(Moroff)
I am now back to where the mid-range shims work,and I have had no issues with my motor,with the mods done to it.
1977 KZ1000 A-1
- mtkawboy
- Thank you received: 16
- bountyhunter
- Thank you received: 337
Well I have just got my valve and seats ground so they will seat properly. But now, even with 2.20 mm shims, i have no clearance on any of my valves. I did some searching and found that this can be caused by the valve stems not being ground with the rebuild. I also found that i can grnd of a maximum of 3mm. First i am going to try the 2.05 mm shims to see if i have some clearance but if i dont how do i know how much to grind off each valve stem? :S 1mm, 2mm, or just have them take off 3mm?
The guy who did my head made precise measurements of valve height before he tore the head apart and then ground the new valve ends to match the same height. He was within one shim size on the final result. Whoever did yours should have done something like that.
FYI, assume that you have zero clearance now and subtract to get center range on your shim sizes and that should get you to a point where you can find shims to work.
- bountyhunter
My FSM says the max is 0.3mm (about.012" ) The spec means total cut off the end. Don't assume the valves have never been ground unless they are new.I also found that i can grnd of a maximum of 3mm.
- jmargrav
1982 KZ750-E3
- bountyhunter
He must have thought he was drilling for oil when he was running the seat reamer. Sounds like he cut them DEEP.I should have known when the guy doing the work told me he has never worked on any motorcycle stuff! But any way, I know he did not take measurements before the work because i have moved down from a 2.55 mm to a 2.20 mm shim and still have no clearance.
- APE Jay
- Banned
- Thank you received: 58
It depends who does your valve work. If the job's done right you only need to swap 2-3 sizes smaller on the shim. If the job's hacked who knows. I've only had 3 valve jobs in my life, 2 were hacked, one was good. What a joy when the job is done correctly.
You have obviously not seen many of these old KZs with ther seats and valve faces beat to death. Takes more than a "few shim sizes" to get it right again
Jay
- APE Jay
- Banned
Man I wish I had a dollar for everytime a guy with a screwed up cylinder has said that.
I can't figure out why anyone would take their cylinder head to a shop that doesn't know how to work on them. Bet you got an automotive type valve job for your money.
Here is the $17.00 solution to your problem
kzzone.com/cams.html
By the way. You can send us the head and we will return it shimable.
Jay
- bountyhunter
Jay
The smart thing I did was to go to the local kawi dealer and weasel the name of the machine shop that they use out of one of their mechanics.... did not want to trust a fool with the head.
