Runs Rough
06 Jul 2008 09:17 #224412 by Vter Bob
Runs Rough was created by Vter Bob
1982 KZ1000 LTD, 29,000 miles. I've been through just about everything on the bike. Fresh gas, plugs, coils, wires, oil, filter, air filter, chain, sprockets, tires, carbs cleaned, etc, etc.
The bike starts fine idles fine but seems to run rough until it gets above 3,000 RPM. If I bog the engine down just a little below 3K RPM (in any gear it seems) the bike will shudder and buck violently. I am also experiencing some minor backfireing on deceleration.
Carbs and I have bad karma but I'm thinking maybe that's my problem. Any suggestions would be greatly appreciated.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
06 Jul 2008 11:30 #224438 by exoskel
Replied by exoskel on topic Runs Rough
My buddy had the problem with backfiring during deceleration he cleaned the gas tank (ie kreem system) and it ran like a charm.
1979 KZ750B4
1998 Yamaha Blaster
South Bend, Indiana
07 Jul 2008 15:45 #224718 by Vter Bob
Replied by Vter Bob on topic Runs Rough
No other guesses? :(
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
07 Jul 2008 16:12 #224726 by SPARKY47
Replied by SPARKY47 on topic Runs Rough
Does it have a mechanical advancer?
1980 KZ500 B2
07 Jul 2008 16:15 #224727 by zskunk
Replied by zskunk on topic Runs Rough
pilots r plugged
07 Jul 2008 16:57 #224734 by Bullitt03737
Replied by Bullitt03737 on topic Runs Rough
Another thing that may help it out, Removing the smog system.
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
07 Jul 2008 17:18 #224743 by Vter Bob
I think I can rule the advancer out. The pilots are what I will work on next. The smog system can be causing the backfiring but it shouldn't make the engine run rough below 3K RPM should it?
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
  • KOOL RYDER
  • KZ 650B2 / KZ 1000E
08 Jul 2008 08:12 #224876 by KOOL RYDER
Replied by KOOL RYDER on topic Runs Rough
Check to make sure that you do not have any cracks in your fuel line.
I checked mine this year after changing the plugs and noticed a small crack.
After replacing it I experienced no further backfires and the performance increased by a factor of 10.
Something else to look into.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
08 Jul 2008 08:27 #224877 by mariozappa
Replied by mariozappa on topic Runs Rough
I haad a similar problem like that on my 650. Turns out the clamps on the intake boots had worked themselves loose, creating an air leak.
I could only hope it would be that simple for you.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
08 Jul 2008 19:56 #225014 by kzwolfsr
Replied by kzwolfsr on topic Runs Rough
Ok guy listen closely I had the same problem as you and I had to keep taking off the carbs to clean them, because junk kept clogging my jets. Where you actually have to start is your inline fuel filter if you have one and oil your advancer on the ignition. Also if you do take off the carbs, pull them out from the left side of the bike , but first take note of how the throttle cable is routed before pulling it out. Take the float bowls off and remove needle jets. Also unscrew the clamps that hold down the needle valve socket and check those filters to see if they are clogged and your main jets check for clogging there too.
Original man of the Caribbean
08 Jul 2008 21:26 #225046 by MFolks
Replied by MFolks on topic Runs Rough
Have you ever done a carb sync using either a vacuum gage or a mercury type stick gauge. In both cases the carbs must be within a certain range or this might happen. Also have you checked the valve clearances?
09 Jul 2008 05:50 - 10 Jul 2008 04:44 #225098 by JR
Replied by JR on topic Runs Rough
Vter Bob wrote:
.... The pilots are what I will work on next....
Are the carb Keihin CV type ? If so then when you have them off for the pilots check and see if you have transition holes. Open the throttle flap and look in and up. Just behind the hole for the pilot air screw may be three tiny holes. If there make sure they are clear. I use a fine pin with a right angle bend on mine (Keihin CV34).
Blocked transition holes can cause a stumble, chug chug at about 2,500 - 3,000 rpm on my 750.
Last edit: 10 Jul 2008 04:44 by JR.
