6 SPEED TRANS
- Mark Wing
Re: 6 SPEED TRANS
05 Jul 2008 11:47
NickW900LTD wrote:
Sorry no it can't, only 650 & 750's share the same trans lay out.
can this 6 speed tranny be used in an early kz? Such as a 1000?
Yorba Linda Cal.
Yorba Linda Cal.
- steell
Re: 6 SPEED TRANS
05 Jul 2008 13:36
Mark Wing wrote:
And possibly the 750 twins, but I haven't had time to check that out real well to confirm it.
NickW900LTD wrote:can this 6 speed tranny be used in an early kz? Such as a 1000?
- kzwolfsr
Re: 6 SPEED TRANS
05 Jul 2008 21:41
I thought I was the only guy searching for 6th gear. Now we all know what these big bikes need
Original man of the Caribbean
- steell
Re: 6 SPEED TRANS
06 Jul 2008 05:59
kzwolfsr wrote:
If you get one you'll be looking for seventh gear
There's very little difference between the 5th gear ratio in the five speed vs the 6th gear ratio in the sixth speed.
The six speed gearbox is just a close ratio trans made for the more peaky 550's.
- SLEEPER650
Re: 6 SPEED TRANS
06 Jul 2008 06:15
do you know what the 1st gear ratio is in the 6 speed? most of the time 1st is lowerand 6th is the same as 5th and all the gears inbetween are different
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- SPARKY47
- 1980 KZ500 B2
Re: 6 SPEED TRANS
06 Jul 2008 06:28 - 06 Jul 2008 07:00
Gear ratio:
6-speed, constant mesh, return shift
Wet multi disc
2.57 (36/14)
1.78 (32/18)
1.38 (29/21 )
1.13 (27/24)
0.96 (25/26)
O.85 (23/27)
For a 500/550 [1980]
Taken from manual in archives.
Wet multi disc
2.57 (36/14)
1.78 (32/18)
1.38 (29/21 )
1.13 (27/24)
0.96 (25/26)
O.85 (23/27)
1980 KZ500 B2
Last edit: 06 Jul 2008 07:00 by SPARKY47.
- SLEEPER650
Re: 6 SPEED TRANS
06 Jul 2008 06:32 - 06 Jul 2008 06:35
so here are the ratio's
kz650 kz550
1st 2.33 -- 2.57
2nd 1.63 -- 1.77
3rd 1.27 -- 1.38
4th 1.04 -- 1.125
5th 0.89 -- 0.961
6th ... -- 0.851
soso all the gears are different and 6th gear is higher than 5th so you will get better performance and better milage.:woohoo:
kz650 kz550
1st 2.33 -- 2.57
2nd 1.63 -- 1.77
3rd 1.27 -- 1.38
4th 1.04 -- 1.125
5th 0.89 -- 0.961
6th ... -- 0.851
78 650sr my baby
82 kz1100
82 kz1100
Last edit: 06 Jul 2008 06:35 by SLEEPER650.
- seanof30306
Re: 6 SPEED TRANS
07 Jul 2008 01:01 - 07 Jul 2008 01:12
SLEEPER650 wrote:
Actually, the KZ550's 6th gear's .851 is only marginally better than the KZ650's 5th gear ratio of .89. The KZ550's stiffer first gear, however, would allow you to change the bike's overall gearing, which would multiply that slight 6th/5th gear difference.
For example, my KZ650 came with 16f/42r sprockets (2.63:1). I initially went with 18f/41r sprockets (2.28:1), but it was way too much. You had to slip the clutch like mad to get it started, and you couldn't roll off from idle in first at all; you'd have to slip the clutch even after it was rolling.
I switched to 17f/41r sprockets (2.41:1)and it is much improved, although I still find myself reaching for 6th gear pretty often. If I had the KZ550's 6-speed gearbox, 6th would be a little lower than the gearing I have, and I could experiment further with the final drive gearing, too. With that stiffer low gear, my 18 tooth front sprocket might work out now, which would also make a big difference in 6th gear. if not, I could at least drop a tooth or two on the rear sprocket. Either way, changing gearboxes gives you a lot more options in final drive gearing; you can't just look at the KZ650's 5th gear ratio and the KZ550's 6th gear ratio and make a judgement based solely on that.
The other problem with highway gearing on these bikes is torque (or lack thereof). When I had the 18f/41r sprockets on, in 5th gear, it was pulling something like 3000 rpms at 55 mph. Hitting the slightest hill caused the bike to scrub speed off tremendously. I believe you could find yourself putting more throttle to it in those conditions, killing the gas mileage you've worked so hard to get.
The other thing I wonder is, with today's modern, overdriven cars cruising at 1600-1800 rpm, would the 6th gear or a change in gearing really make you stop reaching for another gear? The best you're gonna do is cruising at, say 3000 rpm at 55; that's still nearly double the rpms you'd be cruising at the same speed in a car.
kz650 kz550
1st 2.33 -- 2.57
2nd 1.63 -- 1.77
3rd 1.27 -- 1.38
4th 1.04 -- 1.125
5th 0.89 -- 0.961
6th ... -- 0.851
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 07 Jul 2008 01:12 by seanof30306.
