exhaust install, whats the trick?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: exhaust install, whats the trick?
28 Jun 2008 13:58
#222702
the stock kawasaki type crush gaskets are basically just crimped from sheet copper and hard to reuse.the aftermarket gaskets which are more like a crush washer can be hated up and tossed in a bucket of water to aneal them.i spray mine down with copper boat before installing them to help them stick to the head i also wrap rubber bands around the split collars to keep them from falling off while installing header.;)
28 Jun 2008 17:50
#222728
PLUMMEN wrote:
... wrap rubber bands around the split collars to keep them from falling off while installing header.;)
Smells like ... Victory!
  • kztinkerman
  • kztinkerman's Avatar
28 Jun 2008 19:20
#222738
Rubber band, good idea, these little split collar can overlap real easy watch the little buggers
  • kawsakiman
  • kawsakiman's Avatar
28 Jun 2008 20:24
#222744
rubber bands or plain masking tape.
that has to be a hell of a tick since that pipe looks like it's run wide open.
looks good though.
  • mr anderson
  • mr anderson's Avatar Topic Author
29 Jun 2008 06:20
#222772
PLUMMEN wrote:
the stock kawasaki type crush gaskets are basically just crimped from sheet copper.
So would it be possible to just go to the hardware store and pick up some copper washers with the same dimmensions and use them? If its just a copper washer I would think you could.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
29 Jun 2008 07:25 - 29 Jun 2008 07:29
#222793
Those exhaust gaskets aren't just copper washers.
They're basically formed FROM a wide copper washer (think fender washer size), and are rolled/folded over to create a hollow chamber which will flare out and seal the header pipes when the exhaust nuts are tightened onto the exhaust studs.
IIRC, Mark Wing said that older VW copper exhaust header gaskets are the same/nearly the same dimensions, and are a heck of a lot cheaper (about $1 each?) than the Kawi OEM gaskets. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
Last edit: 29 Jun 2008 07:29 by RetroRiceRocketRider.
  • mr anderson
29 Jun 2008 14:30
#222879
just ordered the gaskets from Z1. thanks for all the trade secrets guys. this site is an awesome tool for us do-it-yourselfers! Thanks for sharing yall's insight. will let you know how it turns out in a couple of days!
  • mr anderson
08 Jul 2008 10:52
#224895
finished last night! worked great with all the advise I got. used car wax to hold and rubber bands. thanks again guys.
