Bikey no likey the 20-50
  • donthekawguy
  • Topic Author
18 Jun 2008 06:47 #220677 by donthekawguy
Bikey no likey the 20-50 was created by donthekawguy
Changed my oil and put in 20-50 Castrol. Takes forever to warm up now. Oh well it'll do until August. B)
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
18 Jun 2008 07:42 #220691 by Sandy
Replied by Sandy on topic Bikey no likey the 20-50
I wondered about that when you said you were going to use that oil...makes that much of a difference,eh.:huh:
1977 KZ1000 A-1
18 Jun 2008 08:58 #220701 by mtkawboy
Replied by mtkawboy on topic Bikey no likey the 20-50
Thats what Ive always used, what do you guys advise to use ?
18 Jun 2008 09:59 #220707 by RonKZ650
Replied by RonKZ650 on topic Bikey no likey the 20-50
I used 10w40 in colder weather, 20w50 in hot summer weather. Did that for 20 straight years on the KZ650 using Castrol GTX. Finally the engine was too sludged up to even drain the oil so I abandoned the engine as well as GTX. Now use 15w40 Shell Rotella diesel oil with no problems in 40,000 miles. No matter what weight oil I used I could tell no difference except in cold starts. Don't use 20w50 in the winter. I'm going 10w30 next winter. 15w40 too thick for cold weather.
18 Jun 2008 11:31 #220722 by BSKZ650
Replied by BSKZ650 on topic Bikey no likey the 20-50
dumb question, how does the oil change how a bike warms up, the oil is going to get hot at the same rate, the viscosity is what changes.
77 ltd1000, current rider
76 kz900, just waiting
  • PFC FNG
  • I've got the sickness!!!
18 Jun 2008 12:13 #220727 by PFC FNG
Replied by PFC FNG on topic Bikey no likey the 20-50
Different viscosity = different rates of temp change. Instead of viscosity, think density, the more dense something is, the longer it takes for a temperature change to occur.
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
18 Jun 2008 12:31 #220731 by ltdrider
Replied by ltdrider on topic Bikey no likey the 20-50
I live in the California High Desert. Kind of like the surface of Mars. Cold in the winter (well, cold for CA), and hot in the summer.
I like 10W-40 in the winter, and 20W-50 in the summer. Warm up time always depends on how cold it is when I start up. In the summer, it's about 100° in my garage, and I need maybe 2 - 3 minutes before I can close the choke. In the winter, maybe 5 - 6 minutes.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
18 Jun 2008 12:34 #220732 by bountyhunter
Replied by bountyhunter on topic Bikey no likey the 20-50
That's surprising, back in '79 when I bought mine new the dealers ONLY used Castrol GTX. I used it exclusively until I switched to synthetics about ten years ago. never had a sludge problem. GTX was the only oil back then whose viscosity enhancers could handle the shear stress that the bike transmission puts on the oil.
18 Jun 2008 12:36 - 18 Jun 2008 12:38 #220733 by bountyhunter
I don't think it actually changes how fast the bike warms up. I figured he meant it affected how it ran like how long it took the clutch to start working right. When I ran 20-50 the bike would jerk when I put it in gear while it was cold.
Last edit: 18 Jun 2008 12:38 by bountyhunter.
18 Jun 2008 12:56 #220735 by mtkawboy
Ive been using 20/50 Catrol GTX in everything for 35 years with no sludge problems. Winter riding in Montana isnt a problem, you dont do it. There are times you could but they use cinders on the street corners for ice. Think ball bearings on every corner. Ive ridden Christmas day at 29 degrees once just to say I did it. I know guys who use 10w/30 in 1100 Suzukis with no problems down south. I can see where yould really feel the difference with oil weights in a 650 though
  • donthekawguy
  • Topic Author
18 Jun 2008 23:48 #220845 by donthekawguy
Replied by donthekawguy on topic Bikey no likey the 20-50
It's still pretty cool here and I leave for work at around 1030 at night. Before I changed the oil when I started it I could get it to rev with chove lever just like normal. Now I start it and I can only get it to about 2K rpm with the choke lever. I let it run while I put on my helmet and gloves. I have to leave the choke about half on and can feel it stumble for about 3/4 of a mile. Then it's all good. In the morning it's still about 50 degrees when I leave work. Before I changed the oil all was normal with the clutch and warm up times. I'm not asking for a solution just listing an observation. I'm sure things will be different when it warms up to a hundred next month.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • larrycavan
  • Visitor
19 Jun 2008 05:21 #220859 by larrycavan
Replied by larrycavan on topic Bikey no likey the 20-50
Oils have come a long way since the 70s. 10/40 should be fine for pretty much any street setup. The lower viscosity will get to the top end quicker on cold starts. Maybe if you're in a situation where you're stuck in stop and go city traffic for extended periods of time on a regular basis....then the 20/50 could be a better choice. An oil cooler is the real cure for those situations or performance engines...
If you can afford it, Joe Gibbs makes and excellent break in oil that adds some lubricaion punch. It's fine for regular use as well.
I suggest using it to break in all the engines I build and I know guys that continue to use it after break in.
Larry C
