- Thank you received: 80
Trans lock up
- OnkelB
13 Jun 2008 08:45 - 13 Jun 2008 09:13 #219786
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Trans lock up
Wow, no wonder you couldn´t shift. :blink: Yes, there are two circlips that fit in the grooves for the ball bearings - they´re no. 15 in the diagram, they´re called "Ring, Bearing setting" and the part no. is 14013-004.
The reason you couldn´t find them is that they´re not included in the diagram for the transmission, but the diagram for the crankcases.
Also make sure that the pins on the end cups for the tranny shafts fit into their holes when you assemble the cases.
As for the profile, go to your profile page and click "My profile" in the top menu, then click "My profile info" in the menu on the left, then you can add a signature (among other things).
Last edit: 13 Jun 2008 09:13 by OnkelB.
